Starter troubles
Tleg93
Starter troubles
Post by Tleg93 »
The other day I was fueling up my newly repaired turbo and after I was done I got in to start it and nothing. The headlights were on etc. but it wasn't turning. I know it's the starter so I open the hood and do the Fonzarelli thing (percussive blows to the starter housing) and it started right up.
Now, my question(s) are (I'm at work right now and I can't look up details about the starter) how is the starters on our cars constructed? Is it a solenoid type? Is there a mechanical actuator in there or was it just coincidence that it started after I struck it? These may be dumb questions and I apologize for my ignorance in advance.
--Scott--
1991 - Rio Red SS
There's a solenoid that simultaneously moves the pinion gear out (so it meshes with the teeth on the flywheel or flex plate) and closes the high-current contacts to spin the motor.
Tapping a starter with a hammer is a well-proven way to make a dying starter work when it otherwise won't. If you think about most of the ways a starter can fail (tiny breaks in the solenoid or motor coil, worn solenoid contacts, worn motor brushes), it kind of makes sense that percussion could mask the problem.
Tleg93
Post by Tleg93 »
I thought it was constructed the way you said, I just wanted to be sure that I what I was seeing was a dying starter, which seems to be the case. Thinking about it I guess there is only one type of starter...
--Scott--
1991 - Rio Red SS
professor
Post by professor »
this also means that you can disassemble the starter, remove the solenoid contacts which will look rough and pitted, reface them with a dremel or hand file, and reinstall. That fixed mine for no investment at all.
Hybrids are different - combined with the alternator/flywheel. Citroen or somebody had also done the starter/alternator combo decades ago.
Tleg93
Post by Tleg93 »
professor wrote:this also means that you can disassemble the starter, remove the solenoid contacts which will look rough and pitted, reface them with a dremel or hand file, and reinstall. That fixed mine for no investment at all.
Cool, just what I wanted to hear. :)
--Scott--
1991 - Rio Red SS
Josh replaced his contacts too... I think I vaguely remember him making new ones out of some copper pipe or something. Try searching for "starter" with "legacy777" as the author maybe.
Look at the last thread. I added the link where to order the contacts.
http://bbs.legacycentral.org/viewtopic. ... sc&start=0
You could probably just give your local toyota dealer the following part # 28226-72010 and 28226-72080 and get them. Not sure what costs would be
