Sticky Compilation Thread
I've gotten tired of looking at oodles of stickies, so all the sticky'd threads will be linked in this one thread.
EJ22T Swap into NA Legacy - The List....
Notes on the Ej22T!! - More info added!!
Engine Pull and rebuild tips.
Is my motor an interference motor
Engine Light coming on/off
Hesitation. starting to think it's a big problem.
Unexpected cure for my hesitation problem!!
"Grounding mod" - Major Improvements!
Your Fuel Economy
Turbo cooling system diagram
DIY WRX coolant tank relocation and install
The DOHC installation 'unspoken' details thread
Legacy EJ20G Valve Cover Gaskets!
Engine Compression Testing Values
EJ20K Valve Cover Gaskets - Inner
2.5D or Frankenmotor Swap Info
Fried/Burnt Fuel Pump Connector Info
The PCV System Explained
Hydraulic Lifter Bleeding How-to (video)
Useful EJ22T Engine Part Numbers and Prices
DOHC Timing Belt with counting teeth
A radiator upgrade for the 90-94 non-turbo Legacies
Your Fuel Economy
Re: Sticky Compilation Thread
Might want to double check the dictionary on how to spell "interference".Legacy777 wrote:Is my motor an interferance motor
I just copied & pasted titles from the original threads, and didn't bother checking. It's fixed now.Brat4by4 wrote:Might want to double check the dictionary on how to spell "interference".Legacy777 wrote:Is my motor an interferance motor
It was moved because of misinformation in the thread. If someone wants to start another one, I'd re-link it.
Legacy Central
I feel like ej22t and N/A Head bolt torque specs should be easily noticable on this list.
Do you have a thread with this info?
I searched and searched for 45 minutes today, everythig i found was " torqued to sepcs per haynes manual. " my conversation with stephen today said that that wasnt tight enough.
The torquing procedure pretty convoluted, and is in the FSM you can d/l from me.
If you use ARP studs, the torque specs are going to be different.....and some shops use a different set of torque specs for the stock head bolts.....
Yeah thats what I heard as well. Trying to find out what their specs are. Reason being i just did a head gasket job and the gasket failed instantly. Went off haynes for torque on NON OEM h/g (not my choice) so im trying to see what other torque specs there are.
CJ, here is the latest and greatest from Subaru: (see second post)
http://sl-i.net/FORUM/viewtopic.php?f=5 ... rque+specs
I've used this procedure on 3 different engines, including my SS, with no problems whatsoever. About 60k combined miles. Lord Flashheart is a character, but I PM'd him first and he verified that his shop got these from Subaru last year, and he's used them on many, many engines without a single failure (related to HG's).
I see that is for DOHC, or does that matter any more?
The steps of backing off the bolts halfway through torquing them down makes no sense to me.
Ahh. I didn't catch that you were working on an SOHC. I believe they are different, and I just asked Lord F for them. I noticed my 95-99 Legacy Haynes manual has radically different torquing procedures and specs for DOHC than OEM for DOHC.cj91legss wrote:I see that is for DOHC, or does that matter any more?
Yeah I don't know about that. Like I said, I haven't had a problem with the newest "official" technique by doing that.James614 wrote:The steps of backing off the bolts halfway through torquing them down makes no sense to me.
Added to the first post.
