relocating battery?
kidwired
relocating battery?
Post by kidwired »
I want to move the batt to the trunk.
Anyone done this?
where did you run cable?
what will I need?
I'm thinking batt box and 12' cable + connectors.
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
BAC5.2
Post by BAC5.2 »
Mine is in the trunk.
You need the relocation kit from Summit, it comes with cable and some connectors. You also need a grommet for the firewall, a wire wheel, a fuse or circuit breaker, and a dry cell battery (you absolutely, positively, 100% cannot use a wet cell battery. It's a serious health risk).
Didn't take me very long.
I used a circuit breaker instead of a fuse. It makes it really really easy to reset my battery, simply flip a switch.
I recomend the mod, simply because it makes you badass and people ask where your battery is all of the time :)
kidwired
Post by kidwired »
thanks, I'll check the Summit kit.
I was thinking more of the wieght distribution and making some room for my IC ducts, its going in the drivers fender, like the snorkus.
