How hard will this be to find?
91White-T
Post by 91White-T »
Ok, two possible options, I'm assuming they'll both be a bitch to find since I haven't been able to at all.
1. GC coupe/sedan, OBD1, 5MT, AWD. 93-95?
2. BD/BG OBD1, 5MT, AWD. just 95?
Maybe I'm just TOO picky :?
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
There weren't any OBD-I BD/BG models sold in North America.
91White-T
Post by 91White-T »
Dang. I really like that body style too... So much for an easy turbo swap.
Why is a turbo swap much easier on an OBD-I car?
scottzg
Post by scottzg »
The harness on the 95 up legacies and na imprezas don't have the engine harness combined into the main harness. They go into the firewall and the layout is different.
Why exactly does that make a turbo swap much harder?
scottzg
Post by scottzg »
well, it's not the bolt in, swap 2 wires and ecu that the ej22 ->ej22t or the ej22 -> ej20g job is.
Oh. Neither is it that way for any car that doesn't use the same basic ECU design as ours, right?
jamal
Vendor
Vendor
Post by jamal »
Why not get an OBD2 car and do a WRX swap?
peter@functionauto.com
scottzg
Post by scottzg »
I *think* (and i generally ignore swap stuff) that all turbo stuff through '98 and na stuff through 94 (93 for impreza) had the contained harness and it all makes for easy swapping, 1 or 2 wires and an ecu that plugs in. Then after that they went to a inside/outside engine compartment that complicates a swap.
obdi complicates things, as the obdi2 cars dont share the ecu design, of course, and at least in CA, you can't run a obdi2 engine on obdi1 controls.
I guess really it only makes going to ej22t harder, as theres plenty of obdi2 turboes running around
The body and engine harnesses were/are integrated, but I don't think that makes swapping easier... It makes it hard because you have to sort through all the wires and figure out what you need and what you don't. Right?
scottzg
Post by scottzg »
I dunno, as i said, i don't really pay attention.
I think that you don't really need to sort through because it's all pretty much the same, except for the engine control, and the slight na/turbo differences.
MM or a 20g person would know.
You need both complete harnesses out to do the electricals. Big mess. Lots of wire and connector swapping, after you unwrap lots of tape. Sportcompactcar did a write-up on it in the March '04 issue. They got their info from i-Speed who does the swap all day long. Their guy who swaps the harnesses takes 15-20 hours and he's done lots of them.:shock:
I thought about getting a wrx ej20 to put in. They can be had from nippon motors for $650. The wiring mess made me go with the ej22t.
BAC5.2
Post by BAC5.2 »
1995 was OBD2,
You need a 93/94 GC if you want OBD1
Tleg93
Post by Tleg93 »
Ok, I know it's showing ignorance but what is the GC?
--Scott--
1991 - Rio Red SS
THAWA
Post by THAWA »
gc=first gen impreza sedan
commonly called a gc8 here, but there were never any gc8s sold in the states
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Tleg93
Post by Tleg93 »
Thanks, Hardy, it helps to know the terms when reading the threads.
--Scott--
1991 - Rio Red SS
91White-T
Post by 91White-T »
Ok, so is 93-95 the right range for OBD1 Imprezas?
Post by entirelyturbo »
93-94. All cars switched to OBDII in 95.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
totech
Post by totech »
THAWA wrote:gc=first gen impreza sedan
Yeah, Mine is technically a GM6 lol..
08 GE - SWP
96 BG - SGP
96 CX - EBP
91White-T
Post by 91White-T »
subyluvr2212 wrote:93-94. All cars switched to OBDII in 95.
Ok. Thanks
THAWA
Post by THAWA »
Not all cars, and not even all subarus. 96 it became mandatory.
