My estimate
My estimate
A local exhaust shop is asking 529.00 to install my dp, up and cat back. I was thinking it would be slightly less, not much but a little. I'll probably be installing my uppipe to save some cash. Does anyone have an opinion on this?
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
should be pretty easy, but use a 6 pt impact socket on the bolts because they are likely to be seized up on the exhaust and if your not careful its real easy to round the bolts. I must stress not to round the bolts because then its a real pain in the butt to get them off as they are estremely hard and made to resist heat pretty well.
I used a giant torque wrench set to its highest setting with the impact sockets but you could use a breaker bar.
///M
'93 Legacy SS - part out
I cut my stock exhaust off. I had absolutely no use for it any longer. None of my bolts came unbolted without crumbling.
Do NOT pay 530 bucks to have someone install your exhaust. If you do the uppipe yourself, you pretty much have to take off the rest of the exhaust to do it.
Still to much.
First of all, depending on your downpipe, it should bolt to your stock midpipe. Vikash's did.
So you can take your time, find a cheap WRX midpipe and axleback and modify it to fit later.
FWIW, $500 was the price I was quoted to build me a custom turboback exhaust, including downpipe. Not the highest quality, but for price reference.
What uppipe are you using?
It might be a Tsudo "HKS STYLE" uppipe.
HKS doesn't make a flex uppipe.
I wouldn't worry about it though, my friend has one and it looks pretty legit. It uses a really nice flex-joint from a reputable flex joint company.
nah, you gotta pull the turbo. It's easy enough though, so you can do it no problem, and then you can easily change the rest of the exhaust yourself.
