Upon removing the rust, I found that it went all the way through, so I just removed it and cut the metal around it.
Now, I have a few options.
1) I can figure out how to weld, and TRY to weld a plate over it.
2) I can just use straight up fiberglass and try to get it as smooth as possible.
3) I can pop-rivet a peice of aluminum over the hole and then fiberglass over that to smooth it all out at least a little.
What do you guys think? I am leaning towards #3, but let me hear what you guys have to say.
I must say, it was pretty fun to cut into the car like that. However scary it may have been
Phil
