How to varify it......?
Hi People, got an questions again and hope you guys could help me out.....
just has a chance to get the whole rear suspension with the rear crossmember with the lateral links. But the problem is I don't know its from GC style Impreza or newer model GD Impreza.
I know they looks similar but the GD 4dr should be longer then the GC.
I would like to put it to my 92 turbo with the new C shape end link but I have to make sure it will fits before I put this on.
Could anyone knows how to make sure it or what will be the lenght of both?
Thanks for your help and input...
Ben
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
GD sedans have longer lateral links, and wagons are the same length as the GC and BC.
*I think*
Why can't you find out what car they're from?
I'm in the process of doing the same thing, and I got my lateral links from a 99 impreza on nasioc. I think I'm going to have to cut the bolt off the inside to get it off, though.
*I think*
peter@functionauto.com
Just get it. If you have to get the shorter lateral links.....who cares....shouldn't cost a lot for a junkyard set.
and yes, only the GD sedans had the longer links. The wagons are the same as all the older ones.
- Spelling Nazi
Hi People, thanks for all the input, I finally have time to measure the lenght on both my car and the to-be install rear crossmember and from bolt center end to end. Both of them are same lenght so I assume it will be the same one I want....
Will talk some pics after install with Revlab rear crossmember centering spacer and endlink.
http://www.toronto-subaru-club.com/cgi-bin....;hl=bsc
Ben
Ben
The easiest way to tell is to look at the part right behind the diff. If it can accept a lower arm bar it's from a first gen, if it can't it's from a second gen.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
