Pics of my RS-RA engine
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
irishsetter
I got the engine from Rising Sun Engines. The are in Chico CA.
Nice guys to deal with. The engine came with ECU, cut harness(mostly there though), intake w/airbox, all engine related sensors including MAF, ignitor ect. Also came with AWIC, pump and heatexchanger
I took the only RA, Sorry
IronMonkeyL255
douglas vincent
Are you happy with the AWIC effeciency? Have you checked the temp of the water before and after boost? What boost levels are you running?
I ask this cause I am not happy with mine but hope you are getting better results than me.
I am still doing research with the AWIC. The pump is decent but the heat x-changer is not as big as I would like. its about a 1/3 the size of my radiator.douglas vincent wrote:Are you happy with the AWIC effeciency? Have you checked the temp of the water before and after boost? What boost levels are you running?
I am running about 15psi. I havent gotten any imperical data yet, but after a few High speed pulls the water was warm(not hot).
I want to install some thermocouples soon, to measure both intake air temp and AWIC water temp.
My point was to clarify which turbo you were using.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
douglas vincent
naphappy, meet THAWA. THAWA, meet naphappy.
I had a small heat exchanger which didn't do squat, especially in traffic and at the dragstrip, where it would get hot.
So I upgraded to an AC radiator but it is maybe a 15% increase over the old small one because the tubing is soooooooo tiny barely any water gets through. It suffers a very very narrow urethra.
So now I am looking for an actual radiator or giant tranny cooler.
I also hooked up my two electric fans so they are on when the AWIC pump is on.
douglas vincent
Probably, but in my case, no.
Since I can go forever without hitting boost, I don't need it on. But if I want boost, I wired my SC into the AWIC switch so that I HAVE to have the AWIC on if I want the supercharger to turn on. Kinda of a safety thing.
Hmm, you should try it the other way with the pump on all the time. That should theoretically allow you to remove the heat while you're not on boost right?
douglas vincent
Oh I can do that, I just switch off the SC with its own dedicated switch. But if I am driving down to the local supermarket, I don't need boost, much less cooling.
Like I said, its mainly wired that way so I don't go on boost WITHOUT making sure the AWIC is working.
The factory setup runs the pump @ 28watts normally. When the throttle is opened 80% or more the pump is bumped up to 50watts.
I didnt have the dropping resistor and such so mine is just full power all the time. I also have the radiator fan on that side running all the time.
Rising Sun motors huh? The place I got my GL10 motor from, here in Sacramento, gets all their motors from them. They told me to go talk to them if I wanted an AWIC as well. Cool to know that you got a good deal from them. Did they charge you the same price as their regular 2.0 longblocks?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Matt Monson
- quasi-mod-o
napphappy,
You're just trying to get me to post my pics of the engine internals, aren't you...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Third!snowjob wrote:Please please, plese post your pics Matt.
2014 Volvo S60 T5
2014 Volvo S60 T5
