Shaking steering
IronMonkeyL255
Shaking steering
Post by IronMonkeyL255 »
I've had a problem for a while now, but recently it's gotten worse.
When turning left at low speeds (parking lot speeds), my steering is REALLY rapidly shaky while turning. It seems to have power assist the entire time, but it just feels SOOO not right.
At higher speeds, there is nothing.
Does anyone have any idea what could be causing this? Is it the p/s pump? The rack itself?
Rio Red '91 Legacy SS
Manarius
Post by Manarius »
Well, it could be one of two things. If it's car shuddering, I think it's probably torque lock. Only way to fix that: Expensive.
Other thing: Low RPM. My car, when at low RPM, will shudder in the steering when going around corners. Solution: Take corners faster :twisted:.
But seriously, I think it's a matter of the engine not turning fast enough to run power assist.
IronMonkeyL255
It used to not do it, but it got worse since I put in my new steering wheel yesterday......
IronMonkeyL255
Also, it doesn't do it when turning right at the same speeds.
Worn seals perhaps?
Any ideas...?
Post by entirelyturbo »
My granpa's wagon is doing this as well, although it only does it when you're going straight, and especially at high speeds.
Check your tie-rod ends, be sure they're in good condition. I need to as well.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Do you have an auto or 5spd?
Could be torque bind, could be cv joints....
IronMonkeyL255
auto.
put in a fuse in the FWD fuse holder, and see if your problem goes away.
IronMonkeyL255
Anything I should check for the tie-rod ends?
What fuse should I use?
IronMonkeyL255 wrote:Anything I should check for the tie-rod ends?
Check to be sure the boots are intact, and check that they only rotate in place and don't wiggle around.
IronMonkeyL255 wrote:What fuse should I use?
Doesn't matter 10-15 amp
IronMonkeyL255
I'll give that a try.
subawhatsubawho
Post by subawhatsubawho »
My 90 BJ has the same problem. Does it left or right at low speeds. Fluid is full.
I guess you could call it a stumble.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
BAC5.2
Post by BAC5.2 »
Ball joints?
subawhatsubawho
I'm inclined to say it is the pump.
If I sit in my driveway and turn the wheel it will hold for a second...then go limp...then hold...then limp. Like it is playing catch up.
I think I might rebuild the pump with the help of Josh's thread and do a DYI thread with pics just for the sake of this thread and wanting to know.
Kelly
Post by Kelly »
Bent wheels, bad tires, bad axle.
Which is the most likely to be bad?
If your not sure, swap your rear tires to the front, if it still does it, suspect the axle.
Threshld1
Post by Threshld1 »
i have something along those lines going on with my 93 ss also. i thought it might be my lose ball joints so im changing them and i find a good amount of play in my wheel bearings. ill let you know if the replacements help any
subawhatsubawho
I narrowed mine down to the P/S pump. I noticed last night when I was doing some work on it that the pump is making a loud whinning noise.
Anything making this kind of noise can not be working at 100% (IMO
0perose
Post by 0perose »
resolutions on this???
my car's been doing it for a while
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
