I just got a program called Dyno2003 which runs a 'virtual' Dyno of your car, i.e. it creates a simulation of engine dynamics and estimates the torque/hp. My friend uses it to get an estimation of the payoff of certain mods before actually laying down the cash and the time. It's not 100% accurate, but it gives you a decent idea.
You need to give it a ton of information, and I've found some of it, but there are still lots of gaps. Hopefully you guys can help fill them in, and correct errors
The car is a 92 Sport Sedan
Shortblock
Cylinders: 4
Bore: 96.9mm
Stroke: 75.00mm
Cylinder Volume: 553.00cc
Total Volume: 2212.37cc
Cylinder Heads
Intake Valves: 2
Intake Valve Diameter: 1.420in
Exhaust Valves: 2
Exhaust Valve Diameter: 1.240in
Compression
Compression Ratio: 8.00:1
Combustion Space: 79.01cc
Induction
Induction Flow: ? cfm @ ? inHg
Manifold Type: Forced Induction?
Forced Induction Specifications
Blower Type: Custom Turbo (it doesnt have ours listed)
Island Flow:
Impeller Speed:
Peak Efficiency:
Surge Flow:
Belt Ratio:
Boost Limit: 12psi?
Pressure Ratio:
Internal Ratio:
Intercooler: None
Camshaft
Cam Name: Stock Street/Economy
Intake Lift At Valve: 32.41mm
Exhaust Lift At Valve: 32.336mm
Lifter Type: None (Overhead Cam)
Lifter Acceleration Rate:
Valve Opening/Closing Based on:
Primary timing (Seat to Seat)
IVO 6
IVC 52
EVO 42
EVC 10
Secondary timing (0.050-inch)
IVO
IVC
EVO
EVC
Sorry about the mixed units.
Combing through engine specs
There are two intake and two exhaust valves per cylinder.
Intake lift at the cam is 32.414mm.
Exhaust lift at the cam is 32.336mm.
The primary valve timing is:
IVO: 6 deg BTDC
IVC: 52 deg ABDC
EVO: 42 deg BBDC
EVC: 10 deg ATDC
What are the options for "manifold type?"
IVO: 6 deg BTDC
IVC: 52 deg ABDC
EVO: 42 deg BBDC
EVC: 10 deg ATDC
Oh. I guess "forced induction" is probably right. Though I also kinda like "sequential fire injection" and "invidudual runner."
For information about the turbo, you might refer to the compressor map at the end of the FSM scans Josh is hosting.
