Car acting very funny
Flip_x
Post by Flip_x »
alright lets see how i can tell this, when i try to floor it at round 3.5k rpm it just like lags, ( i can hear the car going faster but it doesnt go) then if i keep doing that then i heard a pop..
i was thinking it could be the tb because maybe the bufferfly is getting stuck..
anyways thanks just ask any questions and i will try to tell u the best i can.
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
Manarius
Post by Manarius »
Sounds to me like transmission lag. My car does that on occasion when I floor it from full stop.
scottzg
Post by scottzg »
search = hesitation
check for vacuum leaks.
Flip_x
Post by Flip_x »
i dont think its a vacuum leak, because sometimes it works great, like earlier today i got it to go 90mph with out that prob..
ej22t
Post by ej22t »
Take a look at the water temp. if the temp. is high and the car has the situation like you just said, then it sounds like the coolant temp. sensor problem.
92 Legacy turbo with EJ20G engine swap \(^0^)/
legacy92ej22t
Post by legacy92ej22t »
Could also be the altenator.
Do the RPMs rise but the car doesn't accelerate? If yes, then it sounds like a clutch problem.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Flip_x
Post by Flip_x »
i think i might have figured it out.
i had a aftermarket thermostat in there. when i changed it the other day with a oem one its doing good now..
oh when i heard that pop. i smelled coolent. but i dont see anything leaking i just smell it. weird.
