Splinter wrote:If you are relying on aluminum to radiate your heat to cool down your processor, you're gonna run into trouble pretty fast
I actually just found a pretty nice miniATX board on eBay for cheap, so it looks like I'm going that way afterall.
Aluminum + Fan = ok (standard..most actually have copper cores but aluminum fins)
Copper + Fan = better
Water = the shit.
'nuff said.
Water = the shit.
'nuff said.
Talking about the aluminum of the case, not the HSF.
Trust me, I may be a little shaky on cars, but PCs I know inside out. Been working as a tech for a few years, and been building computers for 10+. My current machine is running a GFX5900U and A643200+ with only 2 ultra-low-speed fans in the entire system. I'm an absolute master of cool, quiet high-performance PCs.
Your 5900U is quite outdated.
As for me I have FX5600U (which is very outdated) with a 3.0Ghz HT. However, my Abit IC7-G is one kick-ass board.
As for me, I like cool, but I don't mind that my PC sounds like a rocket.
Splinter wrote:
Copper Heat Exhanger= silent
Water = the shit.
Phase Change= truely the shit
Liquid Nitrogen= pinnacle of shit
Fixed it for you
Aluminum cases help act like a giant heat sink for a hot system, they're not the sole cooling component though, unless you're looking at the Zalman case.
Anyway so about those questions I posted earlier, I'm interested.
corsair wrote:Are you going to use an inverter and power a standard AC-DC power supply or are you going to go DC-DC?
DC-DC, an Opus 80W
Also I'll 2nd the use of a rackmount 1U sized case, you can generally find them dirt cheap in surplus auctions or whatever. Why throw a perfectly good case to the shears?
We'll see how things work out as far as fitting the whole thing into the armrest, and go from there
Also. there are specially designed carputer cases that include a power supply starting around $70 bucks, worth a look IMHO.
Yea, most of the PSUs they come with dont have the features that this one has (no reboot on crank, jumpers to set auto shutdown times, battery flattening protection), also a lot of those cases take up a DIN slot, which I dont want to do.
So I've ordered the Epia V8000A miniITX board ($80 CAD on eBay)
The Lilliput 7" Touchscreen ($280 at mp3car.com)
the 80W Opus DC-DC PSU ($80 at mp3car.com)
