Accurate Engine Specs?
BAC5.2
Post by BAC5.2 »
Hey guys,
I need the specs for the Phase 1 EJ25, the EJ22T, and the EJ257.
I need everything.
Bore, stroke, crank profile, head volume, and head gasket specs.
Matt Monson showed me one site, but it didn't seem very accurate. The specs they gave, didn't add up.
Do the FSM's have all of these specs?
Thanks!
jake15
Post by jake15 »
while someones at it, i need to know the same specs for a 89-93 liberty ej20g (no RS-R or RS-RA) i mostly need the head volume, but everything would be much appreciated.
and phil... what are you planning? :mrgreen:
Matt Monson
Post by Matt Monson »
Jake,
57cc
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
napphappy
Post by napphappy »
I can email the FSM specs for the phase I and the 257.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
jake15
Post by jake15 »
Matt Monson wrote:Jake,
57cc
really? i've just spent a couple hours searching the liberty boards and i've come up with 49cc for the DOHC ej20 which ones right? i used to have this really cool web page with all the info on it bookmarked but the link goes to a "website not found" page now.
BAC5.2
Post by BAC5.2 »
Matt - can you verify that the site you gave me was correct?
The piston displacement, calculated by the figures they give, exceed their and Subaru's listed displacement for the Legacy. PD = 2270, Total Displacement = 2217 (or something like that).
I want to get all of the specs together so I can map things out for the machinist.
BAC5.2
Post by BAC5.2 »
Jake - Was it the ravensblade site? He is moving it.
Naphappy - Yea, if you could shoot those over to me, that'd be awesome. BAC5point2 (at) gmail (dot) com
Matt Monson
BAC,
There are some mistakes on the EjCalcs site. I don't remember what they are though. Why don't you post up the specific numbers you are working with, and we can check them for you.
Jake,
57cc comes from a guy on NASIOC, who measured them. I do believe the early WRX Ej20G's were 49cc, but the Legacy versions have more volume. If you look at a set of heads, it is visually obvious that they are much bigger...
Suby Hai!
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
That'll fuck with our compression.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
hackish
Post by hackish »
I just thought of something... Maybe I could CC my head with a needle. 1/2 CC at a time (insulin siringes). That ought to be accurate. Off to the drugstore to buy some vasoline and a siringe :)
-Michael
legacy92ej22t
Post by legacy92ej22t »
hackish wrote:Off to the drugstore to buy some vasoline and a siringe :)
Hehehehe, sounds like you're going to have an interesting night! :shock:
:lol:
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Matt Monson
hackish wrote:I just thought of something... Maybe I could CC my head with a needle. 1/2 CC at a time (insulin siringes). That ought to be accurate. Off to the drugstore to buy some vasoline and a siringe :)
-Michael
Do you really want to advertise how small your member is?
Laurel,
IIRC, when I ran the numbers for Ej22T block with Ej20G Legacy/Liberty heads it was like 6.7:1 or so...
Suby Hai!
Matt Monson
Oh, and I know a guy who swears by using salad oil to CC heads...
Suby Hai!
BAC5.2
Post by BAC5.2 »
Most people use motor oil to CC heads.
We CC'd the head from a 3.4L GM motor at school. We just used water, but it was pretty dead balls on.
BAC5.2
Post by BAC5.2 »
Matt - I just need the internal specs of the three engines so I can see what I need to mix-and-match to get what I want.
And did you say the EJ22T block could go .05cm over before sleeving? How certain of that are you? How much will it weaken the block to go .05cm over?
I also need specific crank specs. I.E. Journal spacing and everything. They SHOULD be the same, but I'm not positive.
azn2nr
Post by azn2nr »
-Michael
Laurel,
um i think i need thoes heads. 30 psi would be simple on that type of compression
-jason
BAC5.2
Post by BAC5.2 »
Why? More boost doesn't always mean more power.....
You could make similar power with 9:1 compression and 14psi.... AND you'd have better low end. The downside is you need to tune it very well or else.
Tleg93
Post by Tleg93 »
We CC'd the head
Ok, I'm a sparkie, what is this? Does it mean to bore the heads with a machine??
--Scott--
1991 - Rio Red SS
legacy92ej22t
No, it's to find out the volume of the heads. CC=Cubic Centimeters
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Tleg93
Post by Tleg93 »
Oh, cubic centimeters!? The way it was being discussed it sounded like a verb.
--Scott--
1991 - Rio Red SS
BAC5.2
Post by BAC5.2 »
When you measure the volume of a cylinder head, its referred to as "CC'ing the head"
Tleg93
Post by Tleg93 »
Yep, I realized that now. Thanks.
--Scott--
1991 - Rio Red SS
azn2nr
Post by azn2nr »
BAC5.2 wrote:Why? More boost doesn't always mean more power.....
i know i know, its just cool to see a boost gauge swing up like that.
-jason
BAC5.2
Post by BAC5.2 »
Bump...
I still need some accurate engine specs!
I would like to get going on planning the long and difficult process of building a monster.
dzx
Post by dzx »
wouldnt 30 psi on a 6.7:1 compression ratio take a long long time to spool up?
///M
'93 Legacy SS - part out
