Automatic Transmission Fluid?
eastbaysubaru
Post by eastbaysubaru »
I know I keep bringing up these rudimentary topics, but I'm sure others are wondering as well, and if not then at least we will have some reference material for future users of this site. So...what automatic tranny fluid is everyone using? I'm in need of changing mine out soon and wanted to get a consensus from our fine community. Thanks in advance.
-Brian
'04 PSM FXT
ciper
Post by ciper »
Redline D4 ATF! http://www.redlineoil.com/redlineoil/atfti.htm#D4ATF Good for dexron ii and iii plus mercon and gl-4 gear oil. Also supposed to improve shifting in Manual trannys that use atf.
Any ill effects of runnin this redline tranny fluid in my tranny that is crappy....prob on it's last leg and has 166k miles on it?
BTW.....I'm goin to move this into the drivetrain forum
eastbaysubaru
Yeah, same question here. I've only got 115K on mine, but am going to be changing the fluid soon.
-Brian
'04 PSM FXT
ciper
Post by ciper »
On my old tranny with 130k or so miles I used it and it seemed great until it broke from an unrelated issue.
I would think that since this fluid has better specs at the temperature extremes it would help to keep your transmission in a consistant characteristic no matter the condition.
