OIL FILTER
OIL FILTER
This is really embarassing but I feel comfortable sharing my shortcomings with you all. Where do I find the oil filter on a BD5 RS legacy turbo. This is my first subaru and I want to do my first oil change. l had a good look under the hood but.............
Mark
Mark
legacy92ej22t
eastbaysubaru
legacy92ej22t
Ya my Forester has the plastic cover underneath. It looks like a skid plate but it's not. It can be a pain to work with.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
- quasi-mod-o
- quasi-mod-o
Yeah, I don't blame you. I've heard stories from other boards of (get this) a shop draining the tranny oil instead of the motor oil. So they would send the car away with no tranny oil and waaaaaaay too much motor oil. Thousands and thousands of dollars of damage result. Apparently people are so stupid that they can't tell the difference between an oil pan and a tranny case...
No thank you, I'll do it myself
Yeah, there are horror stories...
My friend let a local Sunoco station change his oil... they turned the 17mm hex head drain plug into something that can only be described as an 11/16" dodecagon head. The oil filter was on so tight that I had to stab it with a screwdriver and turn it two full turns before I could loosen it by hand. There was no gasket on the drain plug when I removed it either...
Oh, and check this out when you have some time with RealPlayer:
http://cartalk.cars.com/Radio/Back-Trac ... 200044.ram
legacy92ej22t
If you can't trust them to hold the fricken pickles how can you trust them to work on your car?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Hi guys, thanks for the advice. The skid plate came off with ease and the filter was hanging down and after a bit of a wrestle came off. One of the easiest changes I have done. I had a Honda and doing a filter change on one of those is really frustrating. Thanks for the horror stories. Yet more good reasons why I prefer to do filter and oil changes myself. Mark
