What afc's work on a 94 legacy
Just a quick question what afc's would work on 94 NA BC, cause I have a first gen apexi safc and it does nothing, the 7.50$ kinda makes me wonder, and ???, seems all the post about afc on here are on stock turbos and  I have been talking to the guys at smt6 place and all they say they can do for me is timing changes, so any options that have worked on a NA to turbo  or super charged please HELP ME!
						first vincent made a afc 7.50$ with some radio shack thing that compress the maf signal, next on my afc I can turn it all the way lean or rich and it makes no diffrence in the iddle or my air fuel ratios, next the little knobs that you turn to ajust the mixture should light up red when it hits that rpm range but does not on my unit?
						So you have the very original afc. It should work provided its hooked up correctly. I have the apex'i ITC that's like the original safc but controls timing instead of fuel and it lights up as it enters the rpm range. One of the guys i know was using the original afc on his 93 turbo legacy without problems.
							///M
'93 Legacy SS - part out
The knobs are clear when they get power they turn green, then once the car is on all 5 of the knobs flash red one at a time some begining sequence I presume. Next the knobs should light up red when the that rpm is reached, but that is where my problem is the knobs do not light up red when that rpm is reached. I have had a friend come over and looked over the wiring job I did and agreed that everthing is in its place.
						Looks exactly like my ITC. The knobs on mine are red though and turn green when in the rpm range. I expect yours should be red and turn green also. It just makes more sense that way.
Kinda makes me think you got two of the wires crossed but i'm having problems locating a manual for the 5 knob afc online.
here is the apex'i phone number in california, give them a call and find out if its supposed to light up green when it enters the rpm range.
(714) 685-5700 Phone
i know on the pinout diagram, some of the pins are different from n/a to turbo. I don't know if it was any of the relevant ones but you might recheck that.
///M
