ok so my car will not start. i have bad starter contacts and i know this but its not so bad that i cant get it started at least eventualy.
from what ive read i have a bad coolant temp sensor. this from the car turning over without starting unless i hold the gas.
today, well last night i parked outside for the first time in a long time and this morning the car wouldnt start. at first i thought bad starter contacts. but then it started to turn over verry slowly, about 4 seconds a turn. then faster and faster but never up to normal starter speeds. i heald it there until the speed sort of plateaued and let the key off. i could never get it to turn over again.
what is it this time
-jason
terminals are secure. ive had that problem before and its deffinatly not that. flat battery is a maybe. this is the batterys second winter with me. and i dont know when the last time it was replaced as i bought the car used. yet then again. if it were to be a flat battery the starter wouldnt have speed up as it turned more adn more
-jason
