Need Engine Section of an FSM....
BAC5.2
Post by BAC5.2 »
I need another engine section from an FSM. This one is a long shot though.
I need the engine specs for the EG33 from the SVX.
Standard FSM specs are what I need. Bore, stroke, rod and crank bearing journal widths, all that good stuff.
Anyone got it?
sammydafish
Post by sammydafish »
Bore/Stroke is the same as an EJ22, 96.9x75mm I assume the rod length is the same as all the other Subaru engines of the era, EJ22, EJ20, EJ22T are all 130.5mm rods.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Post by entirelyturbo »
As best I know, sammy is correct. The EG33 is nothing more than an EJ22 with two extra cylinders, in the same way the ER27 in the XT6 was nothing more than an EA82 with two extra cylinders.
I can try to dig up some more info tomorrow at work though...
*Formerly DerFahrer*
may want to check out www.subaru-svx.net/forum if you haven't already.
BAC5.2
Post by BAC5.2 »
I need to do some research on the motor.
As much info as possible would be great! Head info would be nice as well.
I want to be as prepared as possible when I get into the project.
I also need cam specs and such.
It may "just" be an EJ22 with 2 more cylinders, but I want some real specs.
BAC5.2
Post by BAC5.2 »
I found a scan!
Now I'm curious. What is your project?
BAC5.2
Post by BAC5.2 »
Top Secret. It will be something to be rekoned with though, that's for sure.
Coolness, those are the best kinds of projects.
