RHD conversion
Blackbart
Vendor
Vendor
RHD conversion
Post by Blackbart »
I just picked up some parts from a RHD clip, they were local and I figured I might take a shot at doing a RHD conversion. I pulled the dash from a LHD to see what I am in for, the bracket that holds the steering column has to be cut an welded to the other side alone with some other tabs if I want to have heat. I am not going to install the A/C. In the engine compartment I will have to move the brack booster to the right side, right where a sensor cluster is located. Not sure yet if I have to swap the harness wires that were under the dash or just modify some wires.
So far it makes doing an engine swap as easy as changing a battery.
Plus, if I do get this done it would be a shame not to put the twin turbo ej20h in it. Where does it stop? Does it ever?
Binford
Post by Binford »
I'm glad somebody's going to do it. I'm sure you'll get it done, and I will be very envious. :-D
Blackbart
Vendor
Vendor
Post by Blackbart »
You may be envious, but I will be surprised!
IronMonkeyL255
Post by IronMonkeyL255 »
That's freaking awesome.
Rio Red '91 Legacy SS
jnorion
Post by jnorion »
Maybe I'm not understanding something, but other than the novelty of it, why would you do a RHD swap?
~Joel
To fit a twin turbo engine.
Post by entirelyturbo »
A WRX came in the other day with an RHD conversion, most definitely incomplete :lol:. The only thing inside was the seats, dash, and some custom wiring. The carpet was removed, the trim pieces under the dash were missing, so all the wiring was all over the place...
But it was kinda cool :D
*Formerly DerFahrer*
BAC5.2
Post by BAC5.2 »
jnorion wrote:Maybe I'm not understanding something, but other than the novelty of it, why would you do a RHD swap?
I think the question should be "Why wouldn't you do a RHD swap?"
jnorion
Post by jnorion »
Well, I personally am very comfortable driving on the proper side of the car. I'm right handed, so I like using that hand for shifting gears. I like being able to pull up to a drive-through and actually reach the window. I would much rather spend the money it would take on other upgrades and modifications.
I wasn't aware of the possibility of a twin turbo swap that was only RHD. So far this is the only reason I've heard that makes sense. Unless you just really like being different... in that case, I wish you the best of luck, hope you enjoy it, and I want to see pictures because it sounds like an impressive project. To each his own.
~Joel
He can also be the fastest mail box bomber around. Fast food is bad for you. Not reaching them is a good thing.
jnorion
Post by jnorion »
Bah. Drive-through is reserved for the coffee stand.
~Joel
Splinter
Post by Splinter »
I know we dont do things on the basis of how easy they are around here, but cant you just import a T-Leg from Japan?
You could even get a broken down one and fix it if you didnt want it to be THAT easy ;)
magicmike
Post by magicmike »
I cant even imagine having to get out of the car to get a dunkin donuts coffee lol
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
eph
Post by eph »
as far as drive thru... just go in them in reverse... we used to do it all the time in my friends car... unfortunately it's a honda... but still...
also had to do it in my fiance's rabbit, her window never liked to roll down.
1991 Legacy L Wagon, FWD to AWD and Automatic to Manual Conversion... then AWD 5M/T N/A to 5M/T Turbo awd swap...
http://www.cardomain.com/ride/879076
