heater and heater controls in 90 legacy
subaru girl
Post by subaru girl »
the heater in our 90 legacy has something wrong with it because when its off and you push the button for the defrosters the blower will work but the air doesn't come out anywhere . well until you hit the dash a couple times then it works. sometimes when i start the car the heater is dead, i can push all the buttons and nothing happens until i smack the dash then it will work. can somebody please tell me what it might be. :?:
Subaru's Are ForEver.
Me and My Husband Have :
90 Subaru Legacy L FWD
90 Subaru Legacy L 4WD
78 Jeep Cherokee,Quadra Trac
Busdriver
Post by Busdriver »
This thread might help...
it's under electrical/heater-blower question.
http://bbs.legacycentral.org/viewtopic.php?t=19514
Stock 1991 Legacy L+ AWD 5MT wagon 191k+ mi
barrykennedy
Post by barrykennedy »
I had the same problem in my 90 legacy LS wagon. I replaced the heater/AC/vent control assembly (the unit that you use to adjust the heat/ventilation etc.) This worked great for about 6 months then the blower went! I replced the blower motor and now all is working as it should.
mattyg41383
Post by mattyg41383 »
I have had this problem happening with my '90... pounding the dash, etc. I took it all apart and tried several things to fix it, with no successful result other than taking the vent out and reaching in to wiggle the wires when it goes off. The '90 has a crummy design between the circuit boards and the output plug. They changed it for 91. I am in need of a properly-working '90 Legacy heater control unit (I will have a post in the marketplace). It has to be a '90, with the yellow plug on the back.
-Matt
-Matt
1993 Legacy SS - auto
1997 Impreza coupe
1986 XT - 14.5s @ 95mph
1990 Legacy wagon "the Red Dragon" -sold (300K miles and it lives on)
