Spring Perches...
BAC5.2
Spring Perches...
Will 92-94 front spring perches fit 04+ WRX springs?
I THINK yes, but I didn't have a loose set to try them out with.
Any confirmation, or do I need WRX upper perches?
belladonna
phil - ryan (pwise) told me that the 1st gen. legacys are compeletly interchangable with the WRX suspension parts... if you're unsure, check out http://www.uklegacy.com/ under Gentral Technical-Pinned- Legacy/Impreza Interchangability
'93 Legacy L Sedan AWD - RIP Kella, July 11, 2008
We're talking about bugeye and newer. All that thread mentions is the 1st gen impreza, and the one post relating to 04 STi stuff says it doesn't fit.belladonna wrote:phil - ryan (pwise) told me that the 1st gen. legacys are compeletly interchangable with the WRX suspension parts... if you're unsure, check out http://www.uklegacy.com/ under Gentral Technical-Pinned- Legacy/Impreza Interchangability
From going out side with a tape measurer right now they seem to be about the same. I can't really reach up in the tower very far, though.
BAC5.2
Yea, I need to know about 04-05 WRX front springs.
Are the front perches different between 90-91 and 92-94?
Luckily I have both types at my disposal.
Phil
Phil
BAC5.2
No, unfortunately you cannot use 04+ WRX springs on an 02-03 or a GC Impreza.
I have 2004 WRX Struts and springs, and the rex tophats fit the front fine, no issues at all. The rears don't work, as the orientation of the lower bolts won't work on the Legacy with the WRX fixed-position tophat.
BAC5.2
Jamal - I'll be able to check for sure on Friday night. If you can check before then, I am EXTREMELY anxious to know!
I have a good feeling they may actually work!!!!
As far as tophats?jamal wrote:
Also Nick what are you using in the rear?
I just reused the stock SS ones...they seem to work fine...and mine were in great condition...
On a completely unrelated note...2 WRX Rear tophats for sale...cheap
BAC5.2
No my spindle hasn't shown up yet. It should be here tonight, though. I'll take everything apart when I get done with class tomorrow (at 1:30).
Or not. How in the hell do you break a knuckle?
Dirty cocksuckers. That's two packages they've fucked up for me, although at least this time they're admitting it.
Looks like I'm not going to San Diego this weekend.
BAC5.2
BAC5.2
I did the suspension on my buddies DSM today, and while I was at it, checked. Definately bigger, and incompatable.
