Contact Info:
John Schroeder
AIM: Ferariguy3
PM me here
Email me: ferariguy3@aol.com
Phone if your really serious: 914-804-4448
Im located at 10598 (its NY and im about 40 min from NYC)
1992 Subaru Legacy SS
2.2 turbo (closed deck motor)
5 Speed
AWD
141,XXX miles
Motor Runs strong, Pulls hard (i have never had it above 4500 RPM though)
Aftermarket:
Wrx Exhaust
Wrx Wheels
Tow Hitch (kid before me wanted to carry bicycles around)
New Parts:
(have all reciepts, totalling: ~$3000)
New timing belt
New water pump
New Valve cover gaskets
New steering boots
New Brakes (including calipers)
New radiator, flange bottle, fill tank
New Clutch, Pressure plate, throw out bearing
New hoses
New plugs/wires/fuel filter/pvc valve
New belts
The Bad:
Needs New tires
Needs alignment
Tranny is a bit slopy, but it shifts smooth and no grinds!
2 TINY spots of rust and thats it! (surface only, will get pics up soon of that)
A few things that are common with a car thats 14 years old. (squeaks and rattles)
EDIT: ABS light is on, because i removed the fuse, ABS DOES WORK, i just didn't like how it stopped in the snow with it, and feel i can handle it better without abs.
EDIT: CHECK ENGINE light comes on when only cruising on the highway, its a cat efficiency, no big deal. I drove the car back and forth to my old school 300 miles away twice in the last 2 months, and NO PROBLEMS!!
Aftermarket parts included, but not installed:
JDM top mount intercooler (newer)
KYB adjustable rear shocks (new)
3 Inch catless downpipe (used)
JDM headlights (new)
Seatbelt conversion kit (so they aren't power anymore)
im sure theres things im forgetting, so as i think of them, ill post them up.
Looking to get $4250 with all the parts included or $3950 without the aftermarket stuff. These prices are absolutely OBO. The car is rock solid, and i would take it cross country and back if given the chance. Im selling because im getting to autocross and road racing and i want something else. With a boost controller and the parts listed above, this car will smoke wrx's.
PICS:
