2 Wheel Dyno
Splinter
2 Wheel Dyno
Post by Splinter »
Unfortunally, the only 4 wheel dyno is quite a trek from here. The shop where Im going to be doing my build only has a 2-wheel, so Im wondering if there's any *safe* way to dyno our cars on a 2wd dyno?
Disconnect the driveshaft?
FWD fuse? (apparently this puts strain on the diff?)
Disconnect the axels?
I know its not going to be accurate, but its mostly to see if the car is running well, and for tuning. I'll take it up to the 4WD place once the basic tuning is done.
Manarius
Post by Manarius »
FWD fuse...but you're not supposed to be driving the car hard on FWD.
Splinter
Post by Splinter »
Yea I dont want to do anything thats going to damage the car
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
then don't put it on a 2 wheel dyno. ;)
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Splinter
Post by Splinter »
Well that's my question, Laurel. Is there any way to do it without damaging the car. I don't think I could have stated it much more clearly.
If the answer is no, then it's no.
Manarius
Post by Manarius »
Splinter wrote:If the answer is no, then it's no.
Well then simply, the answer is no. You have a AWD car, and it wasn't meant to be tested on a 2WD dyno.
Besides, why waste the WHP of those other two wheels. And...I don't know if I'd want to use a dyno as a method of tuning. There have to be better methods.
Splinter
Post by Splinter »
This is why I'd waste the extra WHP
$200-$300 in travel expense alone.
Looks like for tuning, it's gonna be a lot of highway pulls at 4am :/
Richard
Post by Richard »
13 hours? F^ that! Get a g-tech and be happy with that.
Splinter
Post by Splinter »
Well the Autronics SMC that Im putting on will give live horsepower/torque ratings, but the initial setup would really go a lot smoother in a controlled environment, vs flying down the highway at 60mph trying to look at readings on an 8" screen
Post by 555BCTurbo »
How the HELL does it take 13 hours to go 211 km??!?!?!?!
btw...get a wideband O2...it is pretty much vital for tuning
jnorion
Post by jnorion »
How about jackstands on the dyno? ;)
~Joel
Splinter
Post by Splinter »
555BCTurbo wrote:How the HELL does it take 13 hours to go 211 km??!?!?!?!
There's an ocean, a mountain range and a major metropolitan center in the way.
legacy92ej22t
Post by legacy92ej22t »
A good street tune is better then a dyno tune anyways.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I know some people that have inserted the FWD fuse and dyno'd the car on a 2-wheel dyno.
I wouldn't recommend you do that....but it has been done.
DLC
Post by DLC »
Swap in a 5MT FWD tranny :)
Legacy Central
wiscon_mark
Post by wiscon_mark »
MCarp22 on Nasioc did the FWD fuse thingy...on a mustang dyno...my heart is too sad to give you the results :( :lol:
185,000 miles
Kelly
Post by Kelly »
legacy92ej22t wrote:A good street tune is better then a dyno tune anyways.
ditto.
Splinter
Post by Splinter »
ditto.
Kelly, you were running an SMC, right?
Can you give me a run down on what components you were using with it, and a copy of your map?
Penguin
Post by Penguin »
I am with DLC a 5speed 2wd swap would only take like 2 or 3 hours
and they are cheeeeep so slam the gears and not care
-Penguin
1978 DL+GL 4WD Wagon (only ever seen 4!!!)
1993 Turbo White Wagon (EJ22t DOHC FMIC, 4.11 5 speed swap with wrx LSD)
1996 Impeza Outback Sport (wifes car)
2002 Suzuki GSXR-1140 Bored and Stroked
(just to much to list... 202mph on radar @ Daytona)
BAC5.2
Post by BAC5.2 »
DLC wrote:Swap in a 5MT FWD tranny :)
We just completed a 5-speed, Front-wheel-drive, straight cut dogbox.
wiscon_mark
seriously, who wants FWD? :razz:
185,000 miles
Splinter
Post by Splinter »
wiscon_mark wrote:seriously, who wants FWD? :razz:
+1
I'd rather spend a day driving out to the 4WD than switch to a FWD tranny
Penguin
Post by Penguin »
correct me if i am wrong but....
wouldn't you get a higher WHEEL horsepower number?
and the words "bake show" come to mind. you could just melt those poor tires.
AND want to drop about 200 pounds go from AWDauto to FWD5speed
-Penguin
wiscon_mark
no, you probably wouldn't get a higher readng...at least MCarp22 over on Nasioc didn't...82 whp on the dyno with the fuse in. I just don't think the fuse thing is meant to transfer all the power to the front diff, it's really not made for normal use.
185,000 miles
Penguin
Post by Penguin »
I agree,... if you put a fuse in the FWD plug in your AWD engine bay you will get NO GAIN if anything you get LESS power
i think mark misunderstood me,
If you have a 22t AWD AUTO and put it on an allwheel dyno you get "X" as you WHEEL horsepower number.
If you have a 22t FWD 5 speed and put it on a 2 wheel dyno you get a number GREATER then "X" as you WHEEL horsepower number
a?
-Penguin
