I've just scored a toyota CT12A turbo.
I'm under the impression that the wastegate controls maximum boost..... is that right?
These turbos come fitted in pairs to toyota 1J-GTE engines. they all run at 12 psi standard. The toyota 1J is a 2.5 litre straight six, the red line is approx 7.5k rpm and they tend to be very very peaky (do not make boost untill well after 3k rpm)
I was hoping that running a single turbo on the EJ22 I would end up with nearly no turbo lag. Would this turbo be to small? (if there is a tiny amount of boost at 6k rpm i will be very happy)
Is 12 PSI insane on a bog stock EJ22 with 290k km's on it. (Will it just blow the head gasket straight away?)
Thanks in advance, any advice would be greatly appreciated.
