Timing Covers Necessary?
0perose
Post by 0perose »
yeah definately not like NASIOC's OT...
I decided last night I was going to run the legacy without A/C belt or tensioner.. and sans timing belt covers, so I ripped them all off
should be quicker to fix when iminent failure occurs
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
0perose
Post by 0perose »
also, I was considering adding a second alternator where the A/C is.. but then I decided that would suck in the summer
BAC5.2
Post by BAC5.2 »
0perose wrote:yeah definately not like NASIOC's OT...
Bad idea.
One pebble is all it takes to shred a timing belt.
0perose
Post by 0perose »
lotsa people on usmb are running sans covers... I think this might be one of those "the chicken or the egg" debates
0perose
Post by 0perose »
Splinter
Post by Splinter »
If you were running a skidplate I'd imagine running without a belt cover would be fine...
0perose
Post by 0perose »
Splinter wrote:If you were running a skidplate I'd imagine running without a belt cover would be fine...
no skidplate yet, but nothing is being done to the car other than necessary maintenance unit I get one, because skidplate is priority. going to make gas tank skidplate and rear diff protector as well.
I believe that I'll be fine on the road without covers, at least until I get a skidplate to help out some more
Splinter
Post by Splinter »
I put my covers back on after I did my belt, but Ill pull them once I do the heads, Im sealing off the engine bay from the bottom, putting in a reverse scoop and vents (Venturi effect FTW)
So I shouldnt have to worry about pebbles or anything
0perose
Post by 0perose »
Splinter wrote:I put my covers back on after I did my belt, but Ill pull them once I do the heads, Im sealing off the engine bay from the bottom, putting in a reverse scoop and vents (Venturi effect FTW)
cool, can't wait to see how it works
BAC5.2
Post by BAC5.2 »
Meh, it's not difficult to remove the covers.
Taking them off opens up the tensioner and idler pulleys to moisture and potential malfunction.
0perose
Post by 0perose »
I see your point, but every bolt on mine was rounded off or rusted real good.. a couple broke off.. and the covers were cracked to shit anyway...
I'd say it was already open for moisture and potential malfunction..
0perose
Post by 0perose »
still no problems after a few thousand miles (~100miles dirt/gravel roads), a whole day's worth of mudbogging in foot deep nasty mud, and a whole bunch of other crap
(that's without timing belt covers)
Josh Long
Post by Josh Long »
It looks like neither of the cars in your signature are interfearance engines, so just carry an extra belt or belts.
I think you are not likely to have many, if any problems, however if you are boggin' you may encounter a stick or two that may cause more problems than a few pesky rocks.
All that aside I will leave mine on.
sammydafish
Post by sammydafish »
I don't get it... why leave them off, eventualy something will get in there and dammage the belt or even the gears. If your bolts were rusty just get new bolts.
Leaving them off your just waiting for soemthing to go wrong, and you'll be pretty pissed when you're in the middle of nowhere and need a timing belt.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
