So, I'm thinking about removing my amber inserts this weeked (it's nice and all). I was also thinking, how about those white things behind the red plastic...I think vikash called them diffusers. Can I remove those too, or is that not a good idea?
I'm just thinking of what I can do while I have the cases off the car.
Removing Ambers
Manarius
Removing Ambers
bmxkelowna
they are sealed to the sheet metal with butyl. you have to pry them off carefully. a little heat would help also.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I still cant figure out how to get the ambers out of my '93 turbo (sedan). If you know how would you give me some pointers?
THX
THX
92whitelegacy
Take the backing off the sedan tails, from inside the trunk. Use needlenose pliers and just pull and tweak the orange piece untill you coherse it out of there. Takes no longer then 5 mins. I find this a no safety hazard, you will need orange bulbs though, cause the stock ones are white. Or do like me and get BRIGHT red ones JDM all the way
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Except for the fact that it is.92whitelegacy wrote:I find this a no safety hazard
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
