I'm installing an 04' wrx stereo/disc player into my 90'. Can anyone
tell me the 04 wiring pinout. The info I have is wrong and yes I have done a search on this site and 2 others. the12volt.com has neither of the two. Any help would be appreciated.
04' stereo wiring pinout
90' Sedan LS EJ22 5MT
Stock other than 04'WRX wheels & CD changer. Thanks to MTK,Whiteline adj. rear sway,h/d mounts, endlinks,frame bolts & 4 control arms. Front & rear strut braces.
this one from an 02 should work:
http://www.the12volt.com/installbay/for ... ?TID=60043
and so should this:
http://www.the12volt.com/installbay/det ... ype=Stereo
There's also some good info in this thread:
http://bbs.legacycentral.org/viewtopic.php?t=24917
and so should this:
