Hi People, just ordered an metal head gasket from Monteral and then will start of the head gasket job.
One think I would like to know about is the troque spec. on those head bolt?
Can anyone could give an idea what will be the ft-lb of troque on the EJ20G engine?
Thanks for your help!
Ben
Troque Spec.?
ej22t
Troque Spec.?
92 Legacy turbo with EJ20G engine swap \(^0^)/
You have been here long enough to know where the search button is.
http://bbs.legacycentral.org/viewtopic. ... ead+torque
"But its so much easier to let somebody else do it for me"
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
Re: Troque Spec.?
Here's a hint, the search button leads to a list of documents called the FSM in zip/pdf format. That's the only place where it's detailed.ej22t wrote:Hi People, just ordered an metal head gasket from Monteral and then will start of the head gasket job.
Ben
somewhere around scanned page 46.
#82 M4 TRSCCA Rallycross
