Modifying interior cooling/heating (removal)
Splinter
Post by Splinter »
I removed my AC back in february, at least, most of it.
I took out the condensor, the compressor, and the cylinder on the passenger strut tower
What else can be removed?
EDIT: Direction of thread changed
Bheinen74
Post by Bheinen74 »
The AC switch on the hvac controls :roll:
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Splinter
Post by Splinter »
I thought there was something behind the glovebox :roll:
you can remove the evaporator if you want.
You'll need to plug the holes in the firewall as well as the holes on the evaporator box.
Splinter
Post by Splinter »
Legacy777 wrote:you can remove the evaporator if you want.
Is that the big black box behind the glovebox?
Splinter
Post by Splinter »
I cant actually remove the evaporator, because the blower uses it as a duct for the rest of the heating system
Lame.
Splinter
Post by Splinter »
Would it be possible to mount the blower right onto the heater core?
How do cars without AC have their under-dash heating setup?
BAC5.2
Post by BAC5.2 »
I modded the title for clarification.
PRT
Post by PRT »
Splinter wrote:I cant actually remove the evaporator, because the blower uses it as a duct for the rest of the heating system
Remove it out of under the dash, split it open and remove the evaporator from inside, then you can still use it as a duct.
PRT motorsport Rally Team
Splinter
Post by Splinter »
Yes but that doesnt actually save any space :)
0perose
Post by 0perose »
saves weight though
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Splinter
Post by Splinter »
like 4lbs...
anyway
Im trying to save some space so I can move my carPC under the dash
