Yet more electrical oddities.....
IronMonkeyL255
Post by IronMonkeyL255 »
Driving home from class just now, and something weird happened: my ABS, AT oil temp, brake, stop lamp and battery lights came on and off a few times simultaneously for no reason.
They were flickering as though it was due to a short or loose connection, buy what connection would operate all those lights at the same time?
Rio Red '91 Legacy SS
ej22t
Post by ej22t »
Time for the alterntor change... also check with your battery.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
IronMonkeyL255
Really?
I may have to look into that.
Brat4by4
Stratified
Post by Brat4by4 »
Check the two major plugs going into your fuse block (they are on the bottom of the fuse block). Those two connections could turn all of those lights on and off also.
I know this because this is one of the plugs I last figured out after putting my dash back in. :)
IronMonkeyL255
It was the battery.
IronMonkeyL255
It wasn't the battery.
or at least, it wasn't only the battery. I replaced it last weekend, and yesterday the same problem showed up again.
Any particular fuses I should check? What about likely wires?
IronMonkeyL255
I had the alternator checked. It looks good, as does the battery.
It only happens when the headlights are on and partial throttle. At WOT, it doesn't seem to do it.
Please, anyone have any ideas? Any particular fuse I should check?
gt2.5turbo
Post by gt2.5turbo »
dude it has to be your alternator most likely the brushes are worn and cant handle the load from WOT and having your headlights on
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
IronMonkeyL255
at WOT it's fine, though.
I'll try taking it into an alternator specialty shop and see what they say. The Advance auto test didn't seem all that good......
IronMonkeyL255
Okay.
It WAS the alternator.
The autozone and advance auto testers didn't catch the problem. I had it rebuilt by a local shop for under $100, and they did an awesome job of it.
Mellowgorilla
93 Legacy L
Post by Mellowgorilla »
Not sure if mine is the alternator, but this is my battery voltage(Brand new battery): OFF-12.4V ON Running-13.8v ON Running and fans on-13.6v
Here is my problem. When the AC is turned on or the cooling fans turn on, rpm's will bog and bounce between 0 and 800.the car will shake like its going to stall. It will still studder, also, with throttle until 2,000 rpms. The fans are turned off and it will then, cure itself and become a steady idle in ten seconds or less.
I have no idea.
Even with 5/32" on the tires, this car still climbs up a hill on a muddy trail!
98 Legacy GT
Mellowgorilla
Does anyone have an objection to me starting a new topic? I don't think anyone sees my post.
98 Legacy GT
go for it
