Fuel rail problem ---right now
Subtle
Post by Subtle »
For the up grade to STI pinks, I got the 93-94 N/A rails, but these are not top-feed.
Is there a difference between US and Cdn cars, or has the wrecker sent the wrong rails.
Can any one in the North West supply the right ones?
douglas vincent
Post by douglas vincent »
None of the older (90-94) rails are top feed. All side feed.
THAWA
Post by THAWA »
You want STi Yellows, not STi pinks.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Subtle
Post by Subtle »
Thanks guys--my search indicated that the N/A would take any of the newer range of injectors.
Obviously I need specific advice.
Will the yellows fit the N/A side rails that I now have?
IronMonkeyL255
Post by IronMonkeyL255 »
They should.
The problem is the STi pinks must be for a regular WRX, which is top feed. The stock STI injectors are side feed and should fit perfectly into the rails you received.
Rio Red '91 Legacy SS
THAWA
Post by THAWA »
STi Pinks are for EJ207's, not for WRX's(EJ205). You can use them in an EJ205 engine if you tune.
greg donovan
Post by greg donovan »
what is the flow difference between the pinks and the yellows?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
sammydafish
Post by sammydafish »
Subtle wrote:Thanks guys--my search indicated that the N/A would take any of the newer range of injectors.
they'll fit any of the newer side feed injectors. The two types are totally different and are easily visibly identified. The fact that a side feed rail only fits a side feed injector should be intuitive.
Subtle wrote:Will the yellows fit the N/A side rails that I now have?
as long as those rails are not from a 90-91 NA EJ22 then yes, 90-91 rails are the same as turbo rails, all other ones will work. If the rails had red injectors in them, they will fit.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Matt Monson
Post by Matt Monson »
greg donovan wrote:what is the flow difference between the pinks and the yellows?
550cc pink, 440cc yellow, though the flow of the yellows is a long debated issue. Some say 440 and others say 480cc. 440cc is what the ones that I have seen flow test numbers on read...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
You sure about that Matt? You're talking about the yellow side-feeds that come on the USDM STi?
