BIG difference. The opening on our throttle bodies are 2 9/16" in dieameter. The twin turbo throttle body is only 2 1/8" in diameter. WOW.
I am swapping out the NA throttle body to the twin turbo manifold. I have to make a 1/4" spacer though.
bolt spacing is the same, TPS is slightly different, so I need to make a 1/4 thick spacer.
Yeah, its from a legacy, but i have no clue what year, but most likely one of the early twin turbos
