Internet search on ethanol ruin fuel injectors produced article on Toulene or Xylene as additives. I use toulene to clean paint off stained wood.
www.lubedev.com/smartgas/additive.htm
had the most extensive article on those additives to use with acetone! Use 2-3oz per 10gal gas.
I'm stuck in so Calif using ethanol blend because the brand has cleaner gas. Can't win.
Anyone try the acetone and/or xylene or toulene?
Ethanol retrofit?
