Or really, it seems like 10.5 PSI.
I have a WRX intercooler and a MBC, and I just recently started hitting fuel cut if pressure stays at about 10 or 11 PSI for too long.
Any ideas? I may just build Vikash's FCD and be done with it, but I'm just trying to figure out why it's cutting fuel at ~2 PSI lower than it should.........
Why am I hitting fuel cut at 11 PSI?
IronMonkeyL255
Rio Red '91 Legacy SS
IronMonkeyL255
Maybe.
I am judging it by my Autometer boost gauge, and I can't check how off it is since VRG3's scantool won't sync up to my ecu.......
free5ty1e
Yeah, higher elevations seem to result in fuel cut at a lower MAP sensor reading, mine was at 13psig at sea level, and up here in Elko it was down to 10 or 11. I've found that I had to adjust my FCD's clamp voltage down from 4.2V to 3.9V in order to avoid fuel cut up here.
-Chris
91SS 4EAT stock, 200k mi
where is your mbc connected?
has this been going on since the intercooler was installed or did it just start?
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
