Maybe it's the synergy between me and Electric Barbarella (my car), but my car may be an aspiring arsonist. I just bought a book on sniper training for book research and now she seems she wants to participate in some perceived mayhem...
Whenever I drive in traffic I smell gas (at first I blamed it on the domestics around me, but then they were gone and the smell remained). On the highway its fine, and I can't find any leaks. She also doesn't seem to be using any more gas that I can tell. My guess is that she's running rich on open loop and smelling when she goes to idle. There is a little extra black around the tailpipe, but nothing like a diesel Benz. No CEL. All sensors, emissions, and exhaust are original (227K). Could it be the o2? Wouldn't that throw a CEL?
Thanks for any help.
I smell gas
I smell gas
Almost any sensor can give incorrect signals without throwing a CEL... An oxygen sensor can be partially clogged without the ECU knowing.
First, are you sure this smell is coming from your exhaust? If it's not, then you might be leaking fuel somewhere else (which is bad!)... Are all the hoses going to the charcoal canister in good shape?
If it is coming from your exhaust then you're probably running rich.
If you suspect the oxygen sensor, maybe try disconnecting the sensor and resetting the ECU. The ECU will then use its factory default maps, which are a little on the rich side but not by much. If the smell goes away, I'd replace the sensor.
Thanks. I'll give that a shot. I'm not sure where the smell is coming from, everything seems in good shape and I don't see any leaks.
legacy92ej22t
I did a D-check on my car a few months back and I got a code 32
(o2 sensor) and I never got a cel. I checked the o2 sensor and it was totaly dead, and I too was running really rich and smelling gas at idle at the time. Replaced the o2 sensor and it's been great since and car runs much better too. So I would do a D-check and see if it throws a code 32 or any others.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
- quasi-mod-o
Open the hood and take a good whiff (not TOO good though...
). If you smell gas in the engine bay, the very first place you should look is the charcoal canister, as this is the most common place. Look for loose hoses, etc etc. Simple stuff there.
If that checks out, then check other fuel lines in the bay, obviously. Check at the fuel filter, injectors, FPR, rails, etc. etc.
If it's not in the engine bay, then check into you O2 sensor as everyone has suggested.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Re: I smell gas
I've been smelling gas in my car too, but mostly when I have the a/c or heat on. The car sometimes doesn't run the way it should under hard excelleration. This week I am going to change the plugs and wires (all NGK), and if this doesn't solve the problem I will look at the O2 sensor.
Nothing like an old diesel Benzevolutionmovement wrote: There is a little extra black around the tailpipe, but nothing like a diesel Benz.
[color=red][b]1993 Subaru BC Turbo Legacy (193k miles)
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
1989 Honda Elite 50
[/color][/b]
