And yes, most of you are going to think I'm absolutely insane, but I'm still keeping this car for the long haul, I need it badly (running the Subaru Challenge next weekend), and I'll feel better about it.
So I was hoping to do a successful steering rack change last weekend (ended up getting the original one for BC/BF Legacies, and returning the BD/BG GT one I had ordered). I had everything I needed, the new rack, a new set of Whiteline bushings, manifold gaskets, a shit-ton of ATF, a junkyard power steering pump and the reseal kit, etc. I got off work Saturday and headed straight home to start. I had planned for the whole weekend so I could take it slow and do it right, since I've never changed a rack before.
Well, everything went pretty smoothly, barring the exhaust bracket that bolts to the transmission somehow snapping in half and leaving the exhaust in its entirety dangling only by the rubber hangers
The driver's front bolt (driver's side, toward the front of the car) that holds the circular shaped bracket on the rack broke off as I was removing it
In an instant, I realized that this little project was not going to be finished that weekend
I left it for the night, and went to Sears Sunday to get a screw extractor set (yeah, you all know where this is going), and when I got home, I broke the screw extractor off in the bolt fragment. I proceeded to smash my driver's front fender in with my bare fist (I still have some temper problems I guess, no worries, I hope to finally get the body straightened out next summer), and left it for the night.
Monday I was too busy and didn't even touch the car, and last night, I tried fiddling around with it a bit. Soaked the little bastard in PB Blaster and tried hitting the extractor fragment in a counter-clockwise direction hoping to break it loose. Tried pounding the whole thing upward, hoping the welds would break on the nut and I could just slip a new nut in it. I tried drilling into it again, but with the screw extractor stuck in there, I can't.
Keeping the Subaru Challenge in mind, and the fact that my XT has again decided it doesn't want to play DD by having a charging problem and developing ANOTHER exhaust leak (I'm really tired of it doing that too), I broke down this morning.
Ordered a brand-new crossmember, which thankfully isn't as brutally expensive as I thought, $220 something my cost. I did order it overnight though, so I gotta tack on another $30 for freight.
So... I should have it tomorrow, and I'm gonna hopefully try again this weekend. I don't work, so I'll have both full days to do it. I'm gonna find a way to support the engine from up top, and I'm gonna take off the old crossmember. While it's off, I'm also gonna reseal my oil pan, as it's developed a leak in the past 6 months or so. What pisses me off about that though is that I changed the oil first thing when I got home Saturday, so I have 4.5 quarts of completely unused oil in the pan that are gonna go to waste
Then, assuming everything goes okay, I'm gonna install the new crossmember, put the new rack on, put everything back together, make sure it drives okay, have it aligned on Monday (and ask the alignment shop to do my -1º camber in the front like Tire Kingdom refused to do), and go on with my life, including the Subaru Challenge on the 21st.
After all this, I plan on redoing the A/C, having the bodywork done and the car painted, redoing the bad wheel bearing in the right rear AGAIN
