Cooling System Diagrams
Hey Everyone, thanks for letting me into this great place for legacy fans. I just picked up a 1992 Legacy turbo w/ 150k about a month ago, and alot of the stuff here has helped me a great deal(lifters/oil leaks/crank wobble/diagrams....etc. What I would love to know is if anyone has a cooling sytem diagram/part #'s for the EJ22T(blew a line under the airbox) it's like a half-square shape, I think from the turbo to the block. Any help would be great, thanks!
1998 VW GTi VR6 5MT (SOLD)
Check Josh's (Legacy777) information:
http://www.main.experiencetherave.com:8 ... ual_scans/
Theres just about everything you need there....just need to take the time to look around.
I think you are probably refering to the coolant line that goes from the head to the turbo. You can probably get one from someone on here. Check around for a guy named BlackBart. PM him and just describe the line you need. Everything he has is used....but cheap and he ships fast.
That is awesome, thanks!!! I found everything I needed, gonna go order the hose from work today.
