After tranny changed, the speedo bounces(VIDEO)
OK, dont know where i should post this, but a while back, my tranny was either fixed, or replaced, but after the guy did the work, my speedo started bouncing, only at low speeds though, here look!
http://www.youtube.com/watch?v=4kNeFT2VLWk
Post by entirelyturbo »
He might have goofed something up when reconnecting the speedo cable.
Honestly, my car has done this for quite a few years and a few tens of thousands of miles, without anything weird happening.
Still, get on your mechanic's ass about it. That's his poor workmanship, not the age of the car.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Subaru_Nation555
Post by Subaru_Nation555 »
Yeah get the mechanic to make it right. That would drive me absolutely nuts to look at.
'06 Impreza 2.5i wagon
IT DOES, lol, i swear, i go crazy having to look at it.
HobbyWrench
Post by HobbyWrench »
ericem,
You may consider pulling the speedometer cable and lubing it with lithium grease.
I periodically have the same problem at low speeds - particularly when the cable needs relubing and/or it is very cold out. It would make sense that additional friction at these slow revolutions would cause the reading to fluctuate.
Good luck.
Mike
__________________
'90 Legacy LS Wagon, EJ22, NA, 4EAT, FWD w/194K+ miles
IronMonkeyL255
Post by IronMonkeyL255 »
Mine has pretty much always done it. I tried lubing the speedo cable with graphite lubricant, but it didn't seem to help much.......
Rio Red '91 Legacy SS
waaah!! so, why could this happen after the tranny change? i heard there is a lube gun attachment, that gets the grease way in there.
Just a update, i played with the cable, and now its not to bouncy, its much better. But ill try pulling tthe cable see what happens.
BSOD2600
Post by BSOD2600 »
Mines always bounced like that too since I got the car this summer. Should fix it one of these days...
'11 WRX Limited
'94 TW | R.I.P.
So, i guess im not the only one with this problem, but im gona go to that tranny shop, they messed with it, then it started doing this.
