gutting downpipe
IggDawg
gutting downpipe
Post by IggDawg »
any reason I can't just take the downpipe off and drill/smash/crush/push/generally eliminate the cat? Everyone raves about new dp's, and I'm not getting inspected for another year now. on top of that I've heard of people running catless passing inspection. Anyways, are there any dangers from gutting the downpipe other than risking speeding tickets?
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
I know a little about Subarus.
no.....not that I can tell...
Aaron's ej22t
Post by Aaron's ej22t »
I would not recommend it. the cat material is dangerous stuff from what i have heard. you don't want to be grinding that up. i recommend you either spring for a custom dp or an aftermarket one. :o
92 Legacy Turbo \ 5MT \ Silver
LegacyT
Post by LegacyT »
Just get a custum one done or get a prefab like the HKS for 150 bucks or so, and keep the stock downpipe around. You never know in your area it might not pass emissions. Or if you sell the car the new owner may want it returned to stock. Then what? You'd have to shelve out for a new or used stock downpipe which would be $$'y.
Mark,
omahasubaru
Post by omahasubaru »
I have a question for you guys with aftermarket catless down pipes... Does your ECU through any CEL codes or anything from taking the cats out... or does the OBDI not have issues with this?
Thanks - Jon
boostjunkie
Post by boostjunkie »
No CE lights, no driveability problems.
As mentioned, OBD1 computers don't have a second O2 senser for cat efficiency. So no you won't get any CEL's
IggDawg
Post by IggDawg »
so we just have the one wide-spectrum cat? schweet.
-IggDawg
IggDawg is cool.
-IggDawg
no.....we have the one wide spectrum O2 sensor ;)
boostjunkie
So are you saying that I could hook up an a/f gauge to the stock o2 sensor and get some REAL values outta it?
IggDawg
Post by IggDawg »
Legacy777 wrote:no.....we have the one wide spectrum O2 sensor ;)
Smartass :D .
IggDawg is cool.
-IggDawg
eastbaysubaru
Post by eastbaysubaru »
Good question Boostjunkie. Anyone?
-Brian
'04 PSM FXT
IggDawg
Post by IggDawg »
If it's anything like the WRX wideband O2 sensor, it'll have a base voltage like 3.5V (on the WRX). A change in this voltage in either direction (IE 3.2 or 3.8 for example) would signify a leaner or richer mixture. The ECU actually reads a milliamp signal, but the information can be gathered by voltage also.
IggDawg is cool.
-IggDawg
The FSM gives the following info.
At idle, the O2 sensor should read between .1 - 1.0 V
(MT) 1.0 V would signify rich mixture
(MT) 0.2 V would signify lean mixture
(AT) 0.7 V would signify rich mixture
(AT) 0.0 V would signify lean mixture
boostjunkie
Hmmmm, those numbers seem similiar to the values given for my obd-2 o2 sensor in the GT . . . Now I gotta figure out what the bosch wideband o2 sensor outputs are . . .
Anybody know?
