AWIC / Heat exchanger / Pump
BXSS
Post by BXSS »
I just received a ej20g GC8 swap, that came with an air to water intercooler setup instead of the slanty i/c that it should have come with.
I have a front mount so i have no real use for this, but it includes the acutal AWIC/expansion tank, & the heat exchanger / pump for the setup.
I'm not sure what these go for so I'm taking offers if anyone is interested PM me an offer.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
dscoobydoo
Post by dscoobydoo »
Guessing you got a legacy/liberty ej20g instead of a gc8 one.
As far as I know, none of the GC8 cars had AWIC's
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
BXSS
Post by BXSS »
Naa,
Based on the tranny code TY752VB3FA, the tranny (& motor it was attached to?) came from a 1995 wrx / or wrx-sti.
I was told it was out of a '95 WRX so that jives.
When I saw the intercooler I suspected exactly what you said, but the tranny code & newness of all of the hardware on the motor/tranny (perfect cad-plating on all nuts/bolts, soft hoses/wiring harness components...) calmed me down.
I also believe that the Liberty/Legacy motor's came with IHI turbos, my motor has a Mitsu turbo. When I get a second I'll pull a valve cover off to check for those retarded rocker arms the legacy's usually have.
This intercooler was an extra I negociated with the engine/tranny/ecu/harness/sensor package, & was just added on to my pallet - not mounted to my motor.
I was hoping for the correct slanty, but I suppose he gave me an intercooler that was not popular in his opinion.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post by BXSS »
I/C set-up is now off the market (the other 1/2 of my mix up was possibly found).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
livestrong14
Post by livestrong14 »
Pm sent!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
I'm interested in the heat exchanger core up front if it's still available and in good condition.
Sending PM
