Working out S-AFCII Wireing...
Cynt
Post by Cynt »
http://legacycentral.org/library/ECU_Landscape.htm
The install asks for "Air flow / Pressure" signal, am I looking at b48.4 MAP sensor signal?
Thanks.
2006 Steel Grey Impreza 2.5i wagon
1991 Black Trucklinered Legacy SS
gto7419
Post by gto7419 »
I belive you want b48.9 - the maf sensor signal.
I have my own safc II to put in, in the next week or so.
I took a look at the manual and it appears that our ecu aligns to the f2-b pinout on page 56 of the installation manual. That pinout matches ours perfectly and shows the airflow sensor as being the maf sensor.
Take pictures of the install and let me know where you put the unit. Im still debating where to put mine.
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Cynt
Post by Cynt »
Right, but the 91 T-Leg is MAP not MAF... Right? :lol:
I'm still learning this car.
gto7419
Post by gto7419 »
I believe we have a map sensor also? BUT, the ecu adjusts mostly by the maf? I am not sure here... I do know certain ecus like "link" use only the map sensor and delete the maf entirely.
Danny
Post by 555BCTurbo »
Cynt wrote:Right, but the 91 T-Leg is MAP not MAF... Right? :lol:
Wrong...
The Turbo Legacies do have a MAP sensor, but it is basically used to control boost and fuel cut, and doesn't really give the ECU much of a usable load reading...
I used the MAP sensor for my analog deflection input on my Perfect Power, and it works great for that.
