Kill me
Gregmckenna
Kill me
Post by Gregmckenna »
went for a tear tonight... mad at the ex and the girlfriend both being retarded... I was pretty worked up.... somehow I managed to take a curb... an I mean take a curb... our coffee shop has a curb that sticks out 3 feet from the rest an I managed to hit it with the drivers side and go right over it ... did a ton of damage to the car... bent one of my motegi MR12 rims... wrecked a falken tire... I think I can save the tire and the rim isnt to bad so with some paint it may be alright.. however I did totally bend my sway bar and lower control arm... Im going to steal one from a junker but the question I have is will a 02 WRX sway bar fit my car and how many mm is it... my friend has one for 50$ and I might just put it on instead.... I got lucky and didnt bend the unibody but the rocker panel and fender are FUCKED as the car is lowered 3"..... Id like to die about now... oh + jammed the tools in the hood tonight.... its got a nice bend... the car is a 92 SS so its got the turbo crossmember if that matters with the sway bar... also may have done some exhaust damage so what kinda after market headers/ up pipe can I slap on this ... thanks guys... I tried to search but Im just to frusterated right now
Bane
Post by Bane »
sucks... as for the exhaust question, as far as i know, any wrx exhaust setup should work, the only question will be clearance if you're that low (ie equal length header design)
you could probably hit up the local wrx group for stock headers/uppipe and bob's your uncle. I just did this myself.
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
Gregmckenna
anyone know about the sway bar,... I got it apart tonight looks like I only screwed the control arm... I did good tho
IronMonkeyL255
Post by IronMonkeyL255 »
If the WRX bar won't fit, I have my stock bar still. I haven't gotten around to throwing it away yet, since I upgraded to Whiteline bars front & rear.
I'll let you have it for $10+shipping.
Rio Red '91 Legacy SS
