Moderators: Helpinators , Moderators
Splinter
Posts: 3058 Joined: Tue Aug 02, 2005 11:12 pm
Post
by Splinter » Mon Jun 11, 2007 8:47 pm
I bolted on my heads the other day, and the studs didnt protrude past the top of the nuts... I thought they might just need to stretch, but after re-torquing them every day, they dont stretch any more and they're sitting here:
Could they somehow be the wrong length??
Splinter on Wed Jul 18, 2007 6:43 am, edited 1 time in total.
gto7419
Posts: 483 Joined: Wed Dec 13, 2006 10:53 pm
Post
by gto7419 » Mon Jun 11, 2007 10:57 pm
The ej25 head bolts and the ej22 head bolts are different lengths.
IIRC, I had to use ej25 head bolts with the dohc heads because ej22 head bolts wouldn't screw down all the way....
You probably have arp ej25 head bolts???
I dont want to guess at what you should do, but maybe back out the studs enough to get the nut completely on there when torqued?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Splinter
Post
by Splinter » Mon Jun 11, 2007 10:59 pm
Ive got an EJ20G longblock using the ARP pre-99 DOHC head studs
BAC5.2
Posts: 9026 Joined: Thu Jan 29, 2004 8:47 pm
Post
by BAC5.2 » Mon Jun 11, 2007 11:29 pm
Why didn't you use WRX ARP studs?
Splinter
Post
by Splinter » Mon Jun 11, 2007 11:54 pm
Because its a pre 99 dohc block... seemed logical to me
Matt Monson
Posts: 2574 Joined: Sun Nov 09, 2003 8:24 pm
Post
by Matt Monson » Tue Jun 12, 2007 5:29 pm
BAC5.2 wrote: Why didn't you use WRX ARP studs?
Unless I am mistaken, the Ej205 studs are shorter than the DOHC Ej25 studs. I think maybe he actually got shipped Ej205 studs.
Personally, I favour the OEM head bolts. If it's not going to have the heads off with any regularity, I see no point in studding it...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Splinter
Post
by Splinter » Tue Jun 12, 2007 9:02 pm
I found the box they came in, part # 260-4701... on the ARP catalogue it lists that as pre-99 DOHC
Goddamnit whats wrong??
Matt Monson
Post
by Matt Monson » Tue Jun 12, 2007 10:14 pm
I did some looking, and that's the shorter one. The 260-4702 is the longer stud.
I am 100% sure that the Ej205 bolts I have sitting around are shorter than the Ej20G bolts I have. You need longer studs. Sorry.
Suby Hai!
Splinter
Post
by Splinter » Tue Jun 12, 2007 10:23 pm
Just got off the phone to ARP... they said they only make two lengths for subarus, 7.7 and 8.5... I guess I could order the 8.5s and see if they'll work without hitting the cams...
What would be the way to do it, take out one stud at a time and replace it, or pull off the head and use a new headgasket?
BAC5.2
Post
by BAC5.2 » Tue Jun 12, 2007 10:53 pm
Be safe. Pull the head and use a new gasket.
They shouldn't hit the head.
I'm a firm believer in head studs. They're just easier when doing head gaskets and stuff. With high output cars, expect to pull the heads for head gaskets every so often.
Splinter
Post
by Splinter » Tue Jun 12, 2007 11:08 pm
Sigh... just ordered new headgaskets.
My local scooby dealer can get them now at least
Posts: 3043 Joined: Tue Jan 25, 2005 9:14 pm
Post
by 93forestpearl » Wed Jun 13, 2007 8:36 am
If they are bottomed out, they are too far, I think. When I put my motor together, I could have turned them in so far that they would barely protrude out of the head.
Splinter
Post
by Splinter » Wed Jun 13, 2007 8:45 am
Sounds like you had the wrong studs too
they are supposed to seat
Splinter
Post
by Splinter » Wed Jul 18, 2007 5:39 am
Well, now Im at the opposite extreme:
What do you think guys... too close for comfort?
Post
by 93forestpearl » Wed Jul 18, 2007 8:01 am
The factory head bolts don't bottom out so why would the studs have to?
I didn't have to back mine out very far, ~ 1/2" or so. I haven't had any issues yet and I've seen 25psi.
Splinter
Post
by Splinter » Wed Jul 18, 2007 8:06 am
What heads are you running?
Post
by 93forestpearl » Wed Jul 18, 2007 8:27 am
I'm still using EJ22T heads. I hope to change that next summer though, and see how much of a difference in HP they will make.
I turned the studs out just far enough for all the threads on the nuts to engage.
I'm trying to put up a pic, but its seems photobucket has shit the bucket, for the time being.
Splinter
Post
by Splinter » Wed Jul 18, 2007 8:32 am
Well Ive already turned the shorter studs, and purchased these...
Can you think of any problems that could occur with them being so close to the cam?
Theres about 1/8" between the top of the stud and the cam
Post
by 93forestpearl » Wed Jul 18, 2007 8:39 am
I cannot think of a problem arising. With how strong of an alloy the studs are made out of, I wouldn't think they'd stretch much at all. You still have the headgaskets you already trashed? Try torquing one down and seeing what happens.
I don't know what else to tell ya.
Splinter
Post
by Splinter » Wed Jul 18, 2007 8:41 am
actually
lol
I just thought of a problem...
how the hell am I supposed to turn the nuts with an extra inch of stud in the way? lol...
Deep socket 13mm 12 point? gonna be an interesting adventure trying to find one of those...
Post
by 93forestpearl » Wed Jul 18, 2007 8:47 am
*hits forehead*
I'm surprised I didn't think of that either.
Here we go
Splinter
Post
by Splinter » Wed Jul 18, 2007 8:55 am
Scratch that problem, my 12 point does fit over the protruding stud. Wicked.
PS - You're not supposed to store the rocker arms like that
Post
by 93forestpearl » Wed Jul 18, 2007 9:02 am
The rockers were only like that for about 5min while I was puting the heads back together. I cleared out and repumped the lash adjusters right before that.
I'd say I'm at about 12-15k miles since getting the car running. I haven't had any problems yet *fingers crossed*
Posts: 2774 Joined: Sun Nov 23, 2003 12:22 am
Post
by AWD_addict » Mon Sep 03, 2007 10:09 am
Hey Splinter, did you decide to keep those longer studs?
I'm trying to decide what head bolts/studs to use on my 20G heads + 22t block combo.
Splinter
Post
by Splinter » Mon Sep 03, 2007 6:22 pm
I used the longer studs, but after I stretched them and compressed the headgaskets, they do contact the cams in a couple places. After spending a long time on the phone with ARP, we decided the best course of action was simply to cut the top of the stud off with a dremel and a very think cutting disc.
He said another good solution would be putting a small ball bearing under the seat of the shorter bolts, which would be fine if you're not trying to get ridiculous amounts of power out of the engine. You loose a bit of threading in the block this method is the problem.
The problem with my method is that it becomes very difficult to remove the studs in the future.
