EJ20G HP's
Locked
Miguelito
EJ20G HP's
Post by Miguelito »
Hi John (again...)
I'd guess your car is 'bout the same as mine... here it's just
called "200 Turbo"... my guess is therefore that you should have
200HP (stock).
However, I recommened that you dyno-test it, cause the garage where
all modifications were made to my car ( www.stmotors.fi ), they told
me that the actual power output varies a lot amongst Subarus. For
example, my previous car was also a 200 Turbo, '92 model, chip
upgraded, and when we drove it on their dyno, it only had 216HP... no
other mods were made on that car, but anyway... They've had some
(stock) turbo Legacies there with under 200HP when tested.
Another thing, you say you run it on 11 psi boost, if I've converted
that correctly, it's 'bout 0.75 bar (correct me if I'm wrong!), and
that sounds a bit low. Is that 11psi on fourth or fifth gear, going
up a hill with your foot half an inch thru the floor... Don't get me
wrong, that's how I measure the top boost on my car. Anyway, under
those circumstances I have 'bout 18psi boost (again, calculating it
from 1.25bar).
I could of course be VERY wrong here... maybe this is the moment to
ask someone how psi is converted to bar, and vice versa!
cheers,
Miguelito
--- In BC-BFLegacyWorks@egroups.com, "penty" <penty@n...> wrote:
> Hi
> Does anybody happen to know what HP I have on my 2L Lagacy 4 cam
turbo I am from the UK so it has water intercooler as standard.
> What is standard for this car ? and now I have it at 11 psi boost ?
> Thanks in advance
> John
> ----- Original Message -----
> From: JohnnyG
> To: BC-BFLegacyWorks@egroups.com
> Sent: Wednesday, November 22, 2000 65 AM
> Subject: Re: [BC-BFLegacyWorks] LegacyWorks Registry
> Perfectly logical engine configuration for your model, Ralph
> I have learnt from this forum, that the UK / Euro 200hp version
is a variant
> on the Japanese 220hp version... probably to meet your emission
> regulations... I guess that what the NW2BD suffix defines.
> John Gillon
> From: RALPH <ralph.jarvis@u...>
> To: <BC-BFLegacyWorks@egroups.com>
> Sent: Wednesday, November 22, 2000 102 AM
> > Just to confuse matters more on the issue
> > of engine models etc...
> > I own a 1994 BC 2L Quad cam intercooled
> > turbo.(200hp model)
> > The engine IS a EJ20G (EJ20GNW2BD)
> > but it has a sand cast block and hydrolic
> > lifters.
> > Now where does that leave us!!!!
> > Hmmmmmmmmm
> > Ralph :->
> To unsubscribe from this group, send an email to:
> BC-BFLegacyWorks-unsubscribe@egroups.com
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974929677/
Rod
EJ20G HP's
Post by Rod »
14.7 PSI = 100kPa = 1 Bar.
As you indicated, 11 PSI is 0.75 Bar.
Rod.
Sent: Thursday, November 23, 2000 8:47 AM
Subject: [BC-BFLegacyWorks] RE: EJ20G HP's
> Hi John (again...)
> 200HP (stock).
> from 1.25bar).
> cheers,
> Miguelito
> > Hi
> > Thanks in advance
> > John
> > From: JohnnyG
> is a variant
> > John Gillon
> > > turbo.(200hp model)
> > > lifters.
> > > Hmmmmmmmmm
> > > Ralph :->
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974932444/
JohnnyG
EJ20G HP's
Post by JohnnyG »
11 to 12lb is about right for a stock EJ20 220hp... if you have no other
wastegate atuator delaying mods, you have a chip which is probably raising
the MAP sensor input sensing to "fool" the engine management system.
Mind you... running 18lb on a stock MAP sensor must be getting close to
"flat-lining" the sensor output. If you have no other boost control or
engine strengthening, you are asking for trouble runniing 18lb.
The name of the game is to build boost early... not raise the peak boost as
such.
John Gillon
Sent: Thursday, November 23, 2000 10:47 AM
> Hi John (again...)
> 200HP (stock).
> from 1.25bar).
> cheers,
> Miguelito
> > Hi
> > Thanks in advance
> > John
> > From: JohnnyG
> is a variant
> > John Gillon
> > > turbo.(200hp model)
> > > lifters.
> > > Hmmmmmmmmm
> > > Ralph :->
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974985395/
awdturbodude@yahoo.com
EJ20G HP's
Post by awdturbodude@yahoo.com »
I fully agree, I'm a bit worried with a boost that high. I already
had problems with the boost regulator, had to "fool" the boost
solenoid by attaching a vacuum line "T" and a piece of extra hose in
one of the hoses that goes to the solenoid. Then we put a 0,6mm
nozzle (or whatever the english name for it is) on the extra hose so
now the solenoid "thinks" the boost is 'bout 0.15bar less than it
really is. The bigger nozzle (or whatever...), the more I fool the
solenoid. Sounds like a crazy thing to do, but the guys at Prodrive
in the U.K. thought that it would do the same as a piece of software
that they sell (GBP200), although they had never trie it... Anyway,
it works, so now then boost cut defender doesn't bother anymore, but
still of course, the problem is there, too much boost.
BTW, when John C said that he runs on 11PSI boost, I guess that
doesn't mean top boost, how/when do you measure the "normal" boost,
is it when running with steady throttle, and not "everything she's
got"?
cheers,
Miguelito
other
raising
close to
or
boost as
> such.
> John Gillon
> From: Miguelito <awdturbodude@y...>
> > Hi John (again...)
> > 200HP (stock).
where
told
216HP... no
converted
and
going
me
it
> > from 1.25bar).
to
> > cheers,
> > Miguelito
> > > Hi
boost ?
> > > Thanks in advance
> > > John
> > > From: JohnnyG
version
> > is a variant
emission
> > > John Gillon
> > > > turbo.(200hp model)
> > > > lifters.
> > > > Hmmmmmmmmm
> > > > Ralph :->
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974990848/
penty
EJ20G HP's
Post by penty »
Hey "build boost early" you say....now that sounds usefull, so how does one achieve this because my car is less of a LEgacy and more of a LAGacy.
Wibble!
John
Sent: Thursday, November 23, 2000 1:13 PM
Subject: Re: [BC-BFLegacyWorks] RE: EJ20G HP's
such.
John Gillon
To: < BC-BFLegacyWorks@egroups.com>
> Hi John (again...)
> 200HP (stock).
> from 1.25bar).
> cheers,
> Miguelito
> --- In BC-BFLegacyWorks@egroups.com, "penty" < penty@n...> wrote:
> > Hi
> > Thanks in advance
> > John
> > From: JohnnyG
> is a variant
> > John Gillon
> > From: RALPH < ralph.jarvis@u...>
> > > turbo.(200hp model)
> > > lifters.
> > > Hmmmmmmmmm
> > > Ralph :->
eGroups eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974994858?> click here
Dave aka DLC/dackampf
EJ20G HP's
Post by Dave aka DLC/dackampf »
Regulate!
My car has noticeably less lag with the AVC-R than with the Hallman.
If i had a less restrictive intake and better exhaust it would be
even nicer, but for the time being, i'm totally satisfied with it.
a LAGacy.
> Wibble!
> John
> From: JohnnyG
no other
probably raising
system.
close to
control or
peak boost as
> such.
> John Gillon
> > Hi John (again...)
> > 200HP (stock).
where
told
For
216HP... no
converted
and
going
get me
under
calculating it
> > from 1.25bar).
moment to
> > cheers,
> > Miguelito
> > > Hi
cam
boost ?
> > > Thanks in advance
> > > John
> > > From: JohnnyG
version
> > is a variant
emission
> > > John Gillon
> > > > turbo.(200hp model)
> > > > lifters.
> > > > Hmmmmmmmmm
> > > > Ralph :->
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974998057/
penty
EJ20G HP's
Post by penty »
Interesting....anyhoow you never did tell me where you live so I can find out how much postage will cost, I still think your VD0 gauge is the tastiest I've seen, it makes mine look like part of a childs toy :(
cheers
John
From: Dave <mailto:legacycentral@yahoo.com> aka DLC/dackampf
Sent: Thursday, November 23, 2000 4:47 PM
Subject: [BC-BFLegacyWorks] Re: EJ20G HP's
Regulate!
a LAGacy.
> Wibble!
> John
> From: JohnnyG
no other
probably raising
system.
close to
control or
peak boost as
> such.
> John Gillon
> From: Miguelito < awdturbodude@y...>
> > Hi John (again...)
> > 200HP (stock).
where
told
For
216HP... no
converted
and
going
get me
under
calculating it
> > from 1.25bar).
moment to
> > cheers,
> > Miguelito
> > > Hi
cam
boost ?
> > > Thanks in advance
> > > John
> > > From: JohnnyG
version
> > is a variant
emission
> > > John Gillon
> > > > turbo.(200hp model)
> > > > lifters.
> > > > Hmmmmmmmmm
> > > > Ralph :->
eGroups eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975000796?> click here
penty
EJ20G HP's
Post by penty »
....ello..... Miguelito.... hows life in sunny old Finland?
how come your phoning the UK........mmmm ?
anyhoo if I had lets say 14 psi (0.96 bar) instead of my now 11psi what size bleed valve would I need in the boost solenoid? by the way what happens when the boost cutter does cut in....does it stop fuel, or spark?
so many questions so little time
cheers
John
Sent: Thursday, November 23, 2000 2:47 PM
Subject: [BC-BFLegacyWorks] RE:Re: EJ20G HP's
got"?
cheers,
Miguelito
other
raising
close to
or
boost as
> such.
> John Gillon
> > Hi John (again...)
> > 200HP (stock).
where
told
216HP... no
converted
and
going
me
it
> > from 1.25bar).
to
> > cheers,
> > Miguelito
> > > Hi
boost ?
> > > Thanks in advance
> > > John
> > > From: JohnnyG
version
> > is a variant
emission
> > > John Gillon
> > > > turbo.(200hp model)
> > > > lifters.
> > > > Hmmmmmmmmm
> > > > Ralph :->
eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975002089?> click here
EJ20G HP's
I apologize John, i forgot about that entirely and have already sold
it do someone else.
I purchased mine from a company on the east coast called Extreme
Motorsports. They have the -30-0-30PSI gauge that's better than mine
for $45US.
Give them a call and see what they can do.
SummitRacing.com has the AutoMeter 2204 gauge pod to house the gauge
in and secure it. It's $12.95US.
toy :(
> cheers
> John
> From: Dave aka DLC/dackampf
> Regulate!
Hallman.
how
of
> a LAGacy.
> > Wibble!
> > John
> > From: JohnnyG
have
> no other
> probably raising
> system.
getting
> close to
> control or
18lb.
> peak boost as
> > such.
> > John Gillon
> > > Hi John (again...)
just
have
> > > 200HP (stock).
garage
> where
they
> told
Subarus.
> For
chip
> 216HP... no
some
> converted
wrong!),
> and
gear,
> going
Don't
> get me
Anyway,
> under
> calculating it
> > > from 1.25bar).
> moment to
> > > cheers,
> > > Miguelito
wrote:
> > > > Hi
Lagacy 4
> cam
standard.
psi
> boost ?
> > > > Thanks in advance
> > > > John
> > > > From: JohnnyG
Ralph
> version
> > > is a variant
> emission
defines.
> > > > John Gillon
> > > > > turbo.(200hp model)
> > > > > lifters.
> > > > > Hmmmmmmmmm
> > > > > Ralph :->
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975002121/
penty
EJ20G HP's
Post by penty »
Okeydokey... I will try them.
cheers
John
Sent: Thursday, November 23, 2000 5:55 PM
it do someone else.
for $45US.
toy :(
> cheers
> John
> Regulate!
Hallman.
how
of
> a LAGacy.
> > Wibble!
> > John
> > From: JohnnyG
have
> no other
> probably raising
> system.
getting
> close to
> control or
18lb.
> peak boost as
> > such.
> > John Gillon
> > > Hi John (again...)
just
have
> > > 200HP (stock).
garage
> where
they
> told
Subarus.
> For
chip
> 216HP... no
some
> converted
wrong!),
> and
gear,
> going
Don't
> get me
Anyway,
> under
> calculating it
> > > from 1.25bar).
> moment to
> > > cheers,
> > > Miguelito
wrote:
> > > > Hi
Lagacy 4
> cam
standard.
psi
> boost ?
> > > > Thanks in advance
> > > > John
> > > > From: JohnnyG
Ralph
> version
> > > is a variant
> emission
defines.
> > > > John Gillon
> > > > > turbo.(200hp model)
> > > > > lifters.
> > > > > Hmmmmmmmmm
> > > > > Ralph :->
eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975002904?> click here
penty
EJ20G HP's
Post by penty »
Yup thats with my foot .5 inch through the floor in 4th gear, on the other hand if I keep my eyes on the gauge; which is quite hard when flooring it in first/second gear ( my mate usually steers while I peek at the gauge) it zooms up too 11psi then suddenly drops as the engine sucks it all in then sits at about 8 psi as I slap it up through the gears; mind you I still have the gauge attached to the turbi nipple.
I reckon if I tried 18 psi my motor would start spitting it's pistons out the exhaust.
Be nice to try it.... just once though.....maybe twice :)
cheero
John
Sent: Wednesday, November 22, 2000 9:47 PM
Hi John (again...)
200HP (stock).
from 1.25bar).
cheers,
Miguelito
> Hi
> Thanks in advance
> John
> From: JohnnyG
is a variant
> John Gillon
> > turbo.(200hp model)
> > lifters.
> > Hmmmmmmmmm
> > Ralph :->
eGroups eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975004288?> click here
JohnnyG
EJ20G HP's
Post by JohnnyG »
Miguelito,
I would only be worried if you consistently have 18lb at most throttle
positions... I wouldn't worry if it is only peaking intermittently when you
are driving hard.
Yes, your "T" bleed valve is delaying the wastegate action to compensate for
the chip upgrade. This style of modifications to the various closed loop
controls of engine management system, become more difficult to balance as
more performance modifications are done, and hence the trend to use
electronic boost controllers and replace the entire ECU.
John Gillon
Sent: Friday, November 24, 2000 3:47 AM
> got"?
> cheers,
> Miguelito
> other
> raising
> close to
> or
> boost as
> > such.
> > John Gillon
> > > Hi John (again...)
> > > 200HP (stock).
> where
> told
> 216HP... no
> converted
> and
> going
> me
> it
> > > from 1.25bar).
> to
> > > cheers,
> > > Miguelito
> > > > Hi
> boost ?
> > > > Thanks in advance
> > > > John
> > > > From: JohnnyG
> version
> > > is a variant
> emission
> > > > John Gillon
> > > > > turbo.(200hp model)
> > > > > lifters.
> > > > > Hmmmmmmmmm
> > > > > Ralph :->
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/975144378/
JohnnyG
EJ20G HP's
Post by JohnnyG »
John, theory in a nutshell... the turbo makes heat, intercoolers expel heat, compression ratios raise heat, and fuel quantity expels heat
Practical mods in oder of priority...
- bigger exhaust to increase heat differential pressure across the turbo turbine
- less restrictive intake to reduce turbo intake vaccuum
- cold box intake and more efficient intercooler to increase intake charge density
...then mods to control loops of engine management system
Then the sky and your wallet is the limit.
John Gillon
Sent: Friday, November 24, 2000 4:56 AM
Wibble!
John
such.
John Gillon
> Hi John (again...)
> 200HP (stock).
> from 1.25bar).
> cheers,
> Miguelito
> > Hi
> > Thanks in advance
> > John
> > From: JohnnyG
> is a variant
> > John Gillon
> > > turbo.(200hp model)
> > > lifters.
> > > Hmmmmmmmmm
> > > Ralph :->
eGroups eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975144393?> click here
Miguelito
EJ20G HP's
Post by Miguelito »
John,
thanks, that sounds good, at least I don't have to drive around
waiting for the engine to pop ALL the time ;)
I have the boost most of the time around 1bar when driving with a
heavy foot, but as said, sometimes it climbs all the way to 1.25-
1.3bar... which is a bit too much in my opinion, but what the heck,
the car MOVES!!!
cheers,
Miguelito
> Miguelito,
throttle
when you
> are driving hard.
compensate for
loop
balance as
> John Gillon
> From: <awdturbodude@y...>
in
so
Prodrive
software
Anyway,
but
boost,
> > got"?
> > cheers,
> > Miguelito
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975260846/
Locked
