Gold V-covers on a JDM engine =?
BXSS
Post by BXSS »
Hey,
My buddy got a JDM BC engine with GOLD v-covers.
There was some note about STi on his invoice, is the a RS/RA engine??
If it is what are the goodies this has?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
stipro
Post by stipro »
RS-RA's did come with gold valve covers aswell as a gold awic. If it is a real RS-RA motor, then it is a real piece of work. It was buillt by Sti, with the craziest hand ported cylinder heads you ever did see. It has all forged internals with a closed deck block. I real find, if its real.
Adam West
Post by Adam West »
Solid gold? Or plated? <grin>
NuclearBacon
Post by NuclearBacon »
wow, does anyone have a pic of this engine? or know how many were made???
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
know1
Post by know1 »
check splinters build thread. He has one he is building a car around.
As for real RS-RA, it should be signed by someone at sti, and you should be able to see the porting/polishing.
BXSS
Post by BXSS »
Yup , I did a search on "Gold Valve Covers" & the Rs-RA stuff popped up.
The V covers definately look OEM, the AWIC is MIA.
The invoice said BC STi, x'd trans......& the motor has the Gold V-covers so I believe this is a RS-RA.
Is there any way to ID the motor from the outside (without removing the intake man. & looking @ the ports, or taking the whole thing a part to look for the techs sig on the crank....)?
It does have the graph-paper boxes cast into the bellhousing area of the motor which is supposed to mean the motor is closed deck.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
Matt Monson
Post by Matt Monson »
If it's a real RS-RA, the heads will be numbers matched, but you can't see the numbers without removing the timing belt and valve covers. However, where a serial number would normally be stamped (on the top between the pair of runners for the intake manifold) there will be an "S". If you do a search by my user name and "RS-RA" you should be able to find my teardown thread with pictures from before I sold mine to Splinter...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
BXSS
Post by BXSS »
Eastcoastswappers is now selling this motor.
$2000 for the complete motor/wiring/ecu.......
$1500 for the tranny
$3350 for the whole swap.
http://www.rs25.com/forums/showthread.php?t=65362
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
IronMonkeyL255
Post by IronMonkeyL255 »
Damn that's tempting....... :(
Rio Red '91 Legacy SS
BXSS
Post by BXSS »
I have nothing to do with that motor or ECS, I just put the link on here because I figured folks may want to see/have interest in this.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
