Flywheel re-surfacing???
Locked
Alan Croxford
Post by Alan Croxford »
I just went through a clutch and flywheel experience that was
enlightning. I replaced the clutch and resurfaced the flywheel. After
this was done it seemed that I had to push the pedal closer to the
floor to disengage the clutch and even then it seemed like the
transmission was fighting the syncros when I shifted. This was the
case as 2nd gear syncro went away after about 4k miles. I did some
checking and found that Subaru does not recommend resurfacing
flywheels. I thought sure they would like to sell new ones. But on
checking things I found something interesting, the t/o bearing travel
is dependent on the master cyl and slave cyl. and there is only so
much travel available and when the flywheel was resurfaced it moved
the clutch assy."forward" out of the range of adjustment making it
harder to disengage the clutch. The only fix was a new flywheel so I
went with a new light chro-moly unit and now the thing works
properly.At the same time I installed
the STI linkage and a short throw shifter plus the STI transmission
mount,all this really improved matters and was worth it. I did some
figuring and found that it looked like if 1mm was removed from the
flywheel this would be about 3mm travel at the top of the clutch fork
and could be about 15mm at the pedal.
--- In BC-BFLegacyWorks@egroups.com, "JohnnyG" <grilla@i...> wrote:
> To some extent it depends on how you drive, and mainly whether you
change
> the clutch before metal to metal contact occurs through the
friction
disk
> wearing too far. If the flywheel surface is still smooth, no need to
> bother... unless you want to lighten it, but lightening the
flywheel
is one
> of the lower priority steps in the quest for more power and only
allows the
> engine to rev a little more freely.
> John Gillon
> www.clubsub.org.nz
> ----- Original Message -----
> From: Ben Lam <b.lam@u...>
> To: <BC-BFLegacyWorks@egroups.com>
> Sent: Friday, December 08, 2000 6:28 PM
> Subject: [BC-BFLegacyWorks] Flywheele re-surfacing???
> > Does anyone do those flywheele re-surfacing when change the new
Cluch
> > system???
> > I have replace my cluch on 110,000km, and now my car going
200,000km
> > and think its time to do another replacement, but I remember I
> > haven't do the flywheele re-surface at the last cluch replacement,
> > should I do it this time? Where could I take my flywheele to re-
> > surfacing or replace a light-weight.
> > 92 Legacy turbo!
> > To unsubscribe from this group, send an email to:
> > BC-BFLegacyWorks-unsubscribe@egroups.com
eGroups eLerts
http://click.egroups.com/1/9698/0/_/_/_/976285972/
Locked
