sun roof wont close
boricuadotnet
sun roof wont close
As you can tell by the title i have a pretty major problem the sunroof wont close yesterday i had to but my lil fishin boat over the car so it wouldnt get rained on the fuse is fine so i am guessin its the motor. i know that cars with power sunroofs have a way to manually operate it i was wondering where this place is im sure the allenn key under the center console lid is just for this rason any help would be greatly appreciated thanksh
If I remember right you remove the dome light assy. I could be wrong, but I had my headliner out to reseal the sunroof 2 years ago, remember seeing the manual drive and it takes an allen bit.
I'd try to get a bit that size and chuck it up in a drill and run it closed that way. Seems like it'd take forever with an allen wrench.
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
Check the owner's manual. There is a plastic plug in the headliner a little behind the dome light. Pull it out & use the allen wrench in there. I think it's 5mm, a ratchet goes faster. This goes directly into the motor. Check the fuse too. Maybe you have a stick or something stuck in the tracks.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
boricuadotnet
Gregmckenna
