$230 (front and rear)+ Shipping
Product Highlights:
* 6061 Aluminum
* Anodized
* CNC milled
* New zinc coated hardware supplied
Benefits:
* Reduces body roll
* Improvement over stock plastic pieces
* Improves turn-in
* Helps with throttle-off over steer
* Cool-looking
I think I have these right
Applications
GA-013-A (FRONT) ~ 90-04 Legacy/ 94-07 Impreza/ 98-02 Forester
GA-010-A (FRONT) ~ 05+ Legacy
GA-012-A (REAR) ~ 90-99 Legacy/ 94-07 Impreza/ 98-02 Forester
GA-011-A (REAR) ~ 00-07 Legacy
GA-010-A
Small I End Link
GA-011-A
Long I End Link
GA-013-A
Small I End Link (Style 2)
Designed for the narrower front track vehicles such as wagons, GC8, etc.
GA-012-A
C End Link
$100 + Shipping
Product Highlights:
* 6061 T6 Aluminum
* Precision Milled
* Kit includes:
o Throttle body spacer
o Throttle cable bracket *
o Longer throttle body bolts
o New gasket
o Longer vacuum hose *
Benefits:
* Increases fuel economy
* Dyno proven to increase torque by 2-4 WHP
* Increases the torque curve in the lower RPM range
* Looks damn cool!
$85 + Shipping
Product Highlights:
* 6061 Aluminum
* Anodized
* CNC milled
* Precision Turned Bushing Bores
* Cast urethane bushings
$28+ shipping
Subframe Locking Kit
Product Highlights:
* Zinc Coated Hardware
* Two piece design is easier to install and ensures longer reusability as the bolt portion can be replaced at will with a standard easily obtainable bolt.
$90 + Shipping
Lightweight Crank Pulley
Product Highlights:
* 100% made in Canada
* 6061 Aluminum
* Anodized
* CNC milled
* Balanced
* Easy Install
* 695 grams / 1.5 lbs
* NOT under-driven
* Uses stock belts for install
$65 + Shipping
Alternator Pulley
Product Highlights:
* 6061 Aluminum
* Anodized
* CNC milled
* Balanced
* Easy Install
* NOT under-driven
$75+ shipping
Product Highlights:
*6061 Aluminum
*Anodized
*CNC milled
*Balanced
*Easy Install
*NOT under-driven
*Uses stock belts for install
Benefits:
*Allows engine to rev higher
*Improves gas economy
*Helps for heel / toe technique
PM for pricing
Product Highlights:
*6061 Aluminum
*Anodized
*CNC milled
*Adjustable throw and height
*Easy Install
*Universal kit
Benefits:
*Shorter throws means faster shifting
