wtb abs sensor (rear righT)
wildacex187
need rear right abs sensor.
5sp 94 ss
wtb: power antenna, a rear right abs sensor and a rear lsd bolt on diff . pls pm me if u have these parts
wildacex187
abs sensor
Figures you'd need the one that got torn up in the wreck...
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
wildacex187
rr abs sensor.
believe they are but if not I may have one. me i'm in yonkers but sensor in poughkeepsie. I will call brother and see if one available.
let me know if your able to interchange first.
good hunting. bepa
good hunting. bepa
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
wildacex187
- quasi-mod-o
Is that what you needed me to look up wildace? I apologize for that. My only chance to look at FSMs is at home and I've simply been too busy lately. So sorry about that.
Anyway, they are indeed different for each corner. List is $155 each, so I understand you wanting a used one.
Just be sure that whoever removes it is careful, as they're usually corroded into the hub pretty good and are easy to destroy when removing them.
wildacex187
abs sensor
have the right rear abs sensor. may have an extra kicker fuse cover as well.
will have brother contact you. not asking much either.
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
wildacex187
