coolant resevoir
wildacex187
coolant resevoir
hey guys i've noticed that when i fill the coolant metal tank (not the reserve tank) after i turn the engine on some coolant starts to spew out. not at high pressure or anything just slowly. is this normal? am i not suppose to fill it? when the motor gets hot there is pressure built up there with the rad cap and stuff.
5sp 94 ss
wtb: power antenna, a rear right abs sensor and a rear lsd bolt on diff . pls pm me if u have these parts
You mean the one up near the firewall, on top of the engine? If so, that should be kept full, and it shouldn't leak. If its the original one, its actually plastic, and breaks after years of being heat cycled. You can get a new one from the dealer, but you'd be better off finding / buying a metal one from a WRX. There's a couple of threads with pictures and descriptions of how and where people have mounted the WRX ones.
